May 16, 2024, 12:23:56 AM
General Tech
Power steering pump leaking
Topic: Power steering pump leaking (Read 2687 times)
May 19, 2016, 10:01:24 AM »
Has anyone used Wynns Power Steering Stop Leak?
Any good or to be avoided? I know Wynns is usually a fairly reliable name.
Got a leak on the Nissan and I don't really want to spend out on getting it fixed when I'm just about to get rid of it.
Re: Power steering pump leaking
May 19, 2016, 11:00:29 AM »
it wont do any harm but a leaky pump is a leaky pump simple as
May 19, 2016, 04:59:27 PM »
Is that it? No-one else want to tell me something I already know?
Dslam
May 19, 2016, 05:40:55 PM »
I think Spanners has hit the nail on the head. Try it and see.
If it works great, if it doesn't it has to be fixed. A chemical fix depends on the extent and the cause of the leak.
May 19, 2016, 06:23:27 PM »
I had this on one of my rovers, the pump was split with a gasket sealing the halves. The gasket had just crumbled away. If i recall i made a new one, it worked too.
thebigdogsix
May 19, 2016, 06:41:02 PM »
Worked a treat on my kia could not even find where it was leaking from originally three years later still no leaks. i was a bit skeptical to be fair but as i could not even find the leak i thought what have i to lose
Reply #6 on:
May 19, 2016, 07:24:41 PM »
Worth a try then!
Reply #7 on:
May 19, 2016, 07:41:39 PM »
lucas power steering stop leak is also very good if you can get it
