Hi y'all! Looking at a trike project, first one here, and normal 1F/2R layout. Lot's of knowledge on this site so lots of questions here:
I have a roller '78 Suzie GS550E, frame, engine, forks [disc brake], needs rebuild ++. Have '68 CB450 engine needs rebuild. May get a complete 80's Honda V45 Magna near free, unknown condition 'ran when parked', right. Lastly, a '74 Chevy LUV 1.8L 4 speed pickup, built by Isuszu, 'G180-E' OHC 4 in excellent shape, but likely a cast iron block.
There may be a trike in there somewhere. Thinking of the Suzie 550 forks & headstock, if I didn't use V45 frame. There's heavier 550 fork springs available. The CB450 might be most second most reliable engine overall, simple 2 cyl. and about 50 HP. GS550 could be rebuilt but $$$. Thinking V45 Magna 750 engine is a nightmare of mechanical complexity but good torque and midrange and shaft drive. Know little about the V45's.
That leaves the Isuzu engine/trans/rear. Haven't checked on weight but doubtless a couple of hundred pounds, maybe 125-150 kilos? Do you think the Isuszu is a possibility or just too heavy? Sure is tempting!
How heavy a rig could the 550 forks handle? I suppose the V45 forks are more robust, may be better?
Any general ideas from the above parts pile? Thanks for any suggestions, and yes, I already took my meds
