May 17, 2024, 08:38:29 AM *
Pages: 1 ... 250 251 [252] 253 254 ... 791
Author Topic: Manky's Pop.  (Read 1564708 times)
« Reply #3765 on: October 03, 2011, 09:47:11 PM »
I'll give it a go.
« Reply #3766 on: October 03, 2011, 09:50:56 PM »
and of course you can take the drum off and wind it up as much as you cam manually them put the drum on as a ,,,snug,, fit.
also if doing this  check the inner edge of the drum for a wear lip and if need be and very very carefully take the lip away ,,sand it off with a flap disc in the angle grinder but be care full
« Reply #3767 on: October 03, 2011, 10:00:08 PM »
Exactly what PD did this evening Mike.
« Reply #3768 on: October 03, 2011, 10:08:33 PM »
The adjustment isn't the barrel type, it's 2 'wedges' with teeth'. I managed to get it to move forward but it then moved back to it's starting position everytime. From memory , same sort of adjusting used on Mk 3/4 ESCORT rear drums , whch also never worked again once you swapped shoes for the first time.
Again, from my recollection the type on the Sherpa only work on hydraulic travel not handbrake ?
« Last Edit: October 03, 2011, 10:14:15 PM by kapri » Logged
« Reply #3769 on: October 03, 2011, 10:19:52 PM »
ok so if its wedge type strip the shoe,s and adjusters off take the wedge,s apparte wash in solvent and clean up the teeth and slightly deepen them with a junior hacksaw
then make shure all the springs are correct and reassemble
DO NOT LUBRICATE THE WEDGE,S TEETH copaslip is very good when used on most brake /mechanical assembleys but  no use on adjuster teeth
« Reply #3770 on: October 03, 2011, 10:21:32 PM »
i do wish i lived nearer i,d pop over and sort out a few bits for you ,
« Reply #3771 on: October 03, 2011, 10:54:35 PM »
They are Copper greased. Hop in the motor & nip down Mike -g'wan, you know you want to!
« Reply #3772 on: October 03, 2011, 10:59:28 PM »
you know i,d be on my way down if i could but i,m under the doc ,again, back for more tests in the morning
and i still havnt got,wonderland ,sorted properly yet
dobber
« Reply #3773 on: October 03, 2011, 11:13:48 PM »
im getting frustrated just reading about it. must be sending you lot insane
        can i have it in 20 Min's?
« Reply #3774 on: October 03, 2011, 11:17:42 PM »
this is manky monkey land..... being insane is one of the standard requirements to be on this site  or in here ,so to speak Roll Eyes Roll Eyes Cheesy Cheesy
« Reply #3775 on: October 03, 2011, 11:26:07 PM »
It's not a hobby, it's an illness. There's no known cure I'm afraid.
« Reply #3776 on: October 03, 2011, 11:34:11 PM »
its a good job were not in the wild theyde ,,shoot,, us  Smiley
« Reply #3777 on: October 04, 2011, 02:52:52 PM »
A day off from the workshop today -got stuff to do at home &, to be honest, I can't afford the fuel to run over there if I'm not doing a lot. Hopefully Terry &/or Kev will be back to sort the rest of the wiring in the next couple of days, so we can get it running, so I'll be back tomorrow.
I did drive to Aldershot this morning though to "JackHammer's" -a very cool local hotrod shop. I knew it was there, but had never been before. All manner of lovely bits & shiney doo dahs. Apparently they've got a German film crew there on Thursday to film Simon of Nefarious Pinstriping, working on Big John's model A coupe as part of a documentary called Flake n Flames.
While I was there, forum member Postie Dave wandered in, looking for a fuel pump for his Consul. Hi Davey Boy.  Wink
I picked up another 10psi residual valve for 10 quid, (they were 27 on Ebay). Hopefully that might sort the rear drum brake problem by keeping some pressure in the lines, holding the shoes nearer the drums.
JackHammer Speed Shop
« Last Edit: October 04, 2011, 02:54:25 PM by Manky Monkey » Logged
« Reply #3778 on: October 04, 2011, 05:14:08 PM »
Guessing after you drove to Aldershot, you went on to Farnborough?Huh  Grin Grin Grin
Jackhammer is at
33a Farnborough Street
Farnborough
Hampshire
GU14 8AG
(just next to Farnborough North railway station, which is handy if the motor's off the road)
...and what is it you do for a living?!!  Wink
The truck is really coming along..... soooo much work, but it'll be oh so worth it!  Cool
« Last Edit: October 04, 2011, 05:17:49 PM by Tony oily bike » Logged
« Reply #3779 on: October 04, 2011, 05:35:17 PM »
I'm a Postie Tony -I walk the same route every day -I don't know how to get to ...(fill in as appropriate), as people think I do when they constantly pull up, asking for directions. How the hell should I know!
Farnborough/Aldershot -just one big Army barracks isn't it?
