flap
« on: December 15, 2006, 05:15:54 PM » |
Broke me half shaft on my Land Rover yesterday. Anyone got any top tips on how to get the other 2 foot out of the axle case.
« Last Edit: December 15, 2006, 05:29:59 PM by flap »
Did you know I won a Trophy and lost my Cartman hat. Then I won another Trophy. I miss my hat.
« Reply #1 on: December 15, 2006, 07:09:48 PM » |
OOOOOOOOOOOOOOps how the hell did you do that? ?? I will ask my mates as I have never broken one .......... yet!!!
lunatic
« Reply #2 on: December 15, 2006, 07:10:45 PM » |
How did you manage that?! Thats quite an achivement if you did it on the road!
flap
« Reply #3 on: December 15, 2006, 07:21:20 PM » |
Broke on the road, went to pull away from a junction and BANG. It is quite an achivement, thats an inch thick steel bar.
lunatic
« Reply #4 on: December 15, 2006, 07:23:19 PM » |
Ive seen them break off road when the car starts bouncing then suddenly gets grip! I reckon take the diff out would be step one. Then hit it with a big hammer!
flap
« Reply #5 on: December 15, 2006, 07:28:47 PM » |
I'm defiantly going to hit it with a big hammer I've never seen one brake on the road before with a standard diesel engine in, Its usually the V8's that break 'em.
« Last Edit: December 15, 2006, 09:52:43 PM by flap »
« Reply #6 on: December 15, 2006, 08:09:21 PM » |
Flap proves yet again that, given enough time, he can break just about anything. Good job you had 4 wheel drive to get you home.
lunatic
« Reply #7 on: December 15, 2006, 08:17:43 PM » |
A friend of mine threw 2 pistons through the block on a v8 landie, then managed to drive it home! Was glowing nicely when he got back what with it having no coolant!
« Reply #8 on: December 15, 2006, 08:20:10 PM » |
Not recommended in the owners manual I'm sure.
Terrortubby
« Reply #9 on: December 15, 2006, 08:22:16 PM » |
Probably no help at all, but if you use nitro-glyserine..............
I hope you get it fixed
Gary
lunatic
« Reply #10 on: December 15, 2006, 08:23:50 PM » |
Just stand well clear!
toad
« Reply #11 on: December 15, 2006, 09:19:26 PM » |
there be two types of diff in them there rand lovers! at a guess id say you probably got the most common type! does it have a removable cover on the rear end of the diff housing??? if it does,nt you should be able to remove the opposite halfshaft and pass a long bar down the tube and through the diff and drift the broken part out! if you have the other type its a bit more complicated! too long to type here but i,ll come up and do it if ya get stuck!!! by the way it looks like that shaft was knacked from the factory look at the oil stained shaft and the the clean break!!
flap
« Reply #12 on: December 15, 2006, 09:52:08 PM » |
No removable cover on the back, The diff pan's welded on. Will try and push it out as you said but I've think I'll have to take the diff out. I've no idea why it broke I presume its been in there for 30 years but it does look odd.
flap
« Reply #14 on: December 23, 2006, 10:20:10 AM » |
Me new half shaft arrived yesterday, I ordered some other bits at the same time. Total cost less than 23 quid Bargain. Off out to fix it soon.
