May 20, 2024, 08:48:34 PM *
Pages: 1 ... 764 765 [766] 767 768 ... 791
Author Topic: Manky's Pop.  (Read 1567090 times)
« Reply #11475 on: March 05, 2020, 12:33:35 PM »
Smiley I've got to visit Mr Loon soon, who hopefully has one. Like the socket, if I buy one I'll probably never use it again.
Yeah, I'm wondering about putting the wheels on, but to get the whole thing back under the chassis I'd have to remove the shocks as well as the axle stands, but might be the way to go.
Dslam
« Reply #11476 on: March 05, 2020, 05:50:47 PM »
I've got one if you need to borrow it mate
« Reply #11477 on: March 05, 2020, 05:58:43 PM »
Thanks Andy. If Loon doesn't have one, I'll be in touch Smiley l
« Reply #11478 on: March 05, 2020, 07:42:43 PM »
Andy, Use a 3' bar, and give it a good "hoik", it wont fall off, and you can torque it up when the plot is on the road, if you must!! If you're down my way I have a large Torque spanner, do it then, progressing well now Shocked Shocked Morrag
« Reply #11479 on: March 05, 2020, 08:41:38 PM »
I’ve got one I can grab from my unit over the weekend
« Reply #11480 on: March 05, 2020, 09:35:42 PM »
I need to hoik it up now cos the drive shafts pass through the hubs, with a flat plate on the end that bolts to the face of the hub. So I'd have to pull the shafts out to access the nuts.
My daily driver's at the garage for a service, so assuming I get it back tomorrow I'll nip over to Loony's workshop. If no luck there, I'll borrow yours Archie if that's alright, (might need a second pair of hands to steady the axle anyway). Easier than travelling to Surrey to Mr Dslam, but thanks for the offer Andy Smiley
« Reply #11481 on: March 06, 2020, 11:11:53 AM »
sure thing, got a family lunch tomorrow at 12 but all good apart from then
« Reply #11482 on: March 06, 2020, 07:37:42 PM »
Torque wrench collected from Loony. I'll give it a go tomorrow afternoon. The nuts need to be torqued to 155 lbs, so not sure if I can hold the axle still & tighten them at the same time Smiley
« Reply #11483 on: March 08, 2020, 07:55:29 PM »
Hub nuts tightened. They're supposed to be 210 Newton Metres, which was the highest setting on Loony's torque wrench, but I couldn't physically tighten them that much, even with the extra leverage of the long torque wrench handle, so settled for "hoiking" them up until the veins started to throb in my forehead & calling that good enough. Locking tab washers hammered over & drive shaft face plates wire brushed clean & repainted. Large O rings & bearing spacer rings refitted.
Tomorrow I need to buy some gear oil to lubricate the splines before fitting.
« Last Edit: March 08, 2020, 08:02:39 PM by Manky Monkey » Logged
« Reply #11484 on: March 08, 2020, 08:00:23 PM »
« Reply #11485 on: March 09, 2020, 12:34:47 PM »
its a pity that socket isnt 54mm. im in the market for one
« Reply #11486 on: March 09, 2020, 06:19:14 PM »
It cost a bloomin' fortune -about a pound a millimetre for the socket & adaptor. I'd send it to you, but the postage to Oz would probably be even more!
Torrential rain here again today. Fortunately it started just as I finished work, but I spent the afternoon running various errands -returning Loony's torque wrench, buying axle oil, some bolts, more gas cannisters for my little butane heater etc, (I've got the big heater now, but the little one's handy for directional heat to dry paint).
I also picked up the new generator I ordered from Screwfix after my last one eventually died. Someone gave it to me a few years ago so I can't complain. 190 quid for the new one. Well that's a bit bigger than I expected, but hopefully won't struggle quite so much to run my drill & angle grinder.
So nothing to report, but more shiny stuff in the garage.
« Reply #11487 on: March 09, 2020, 06:23:32 PM »
Loon & I were due to go to the big Dutch hotrod show in a couple of weeks time. Originally there were 4 of us going, but it came down to just him & me. Talking to him today, we've decided to give it a miss. It's a great show, but it's the road trip we enjoy & it's just not the same if you're not part of the convoy of hotrods. I will get the Pop back there, but not this year.
« Reply #11488 on: March 09, 2020, 06:49:38 PM »
At least you must feel you're making real progress now!
« Reply #11489 on: March 10, 2020, 07:04:07 PM »
Yeah, I'm gradually emptying the bags of nuts & bolts. I actually took 2 Post Office plastic trays back to the depot this morning, (the letters arrive stacked in them, but every Postie has a garage full of them), so parts must be goi g back together.
Bit of a backward step again today though. I oiled the drive shaft splines & slid the shafts back into the axle, but found one hub has some free play, not rotating, but about 2mm back & forth on the stub axle. Looks like the bearing needs hoiking up further onto the stub. I can't physically tighten it any further on my own, so went out & bought a 3 foot long breaker bar for the socket this afternoon & will enlist the help of some youthful brute strength for the hoiking.
Archie, are you free? Smiley
