May 20, 2024, 07:58:51 AM *
Pages: 1 ... 280 281 [282] 283 284 ... 791
Author Topic: Manky's Pop.  (Read 1566641 times)
« Reply #4215 on: January 13, 2012, 08:58:44 PM »
Ah, i remember doing the rear floor and inner rear arches on one of them. It were no fun!
well its inner+outer sills (now box section) pass front floor, drivers floor to sill,,little piece on inner wing and both rear body mounts,,, Roll Eyes bet i find more Shocked
lunatic
« Reply #4216 on: January 13, 2012, 09:06:45 PM »
Theres always more!
« Reply #4217 on: January 13, 2012, 09:16:38 PM »
My daughter had a Fiat 127 that failed its MOT cos the floor was only connected to the rest of the car by rust - she was most upset when even the scrapyard didn't want it!
lunatic
« Reply #4218 on: January 13, 2012, 09:23:56 PM »
Ive heard of a few fiats like that!
« Reply #4219 on: January 13, 2012, 09:26:08 PM »
    arn,t all fiats like that?Huh??
steve brock
« Reply #4220 on: January 13, 2012, 09:58:11 PM »
Oi mr manky do you want two 5mm holes in it to tap for studs ? you could weld them n the polish them clean from front... I may do the other monkey on this site too. Smiley
« Reply #4221 on: January 13, 2012, 11:08:28 PM »
Which other Monkey?
I guess that's the best way of attaching mounting studs isn't it. Can the eyes & mouth be bored to about half the depth of the plate, just to give it a bit of 3 dimensionalism -is that a proper word?
I've drawn 3 of those heads in different sizes, 3,4 & 5 inches wide. I shall check with my artistic consultant, Mr Lunatic, tomorrow to see which looks best.
Never drawn the MMMotors logo from the face forward prospective before, so not sure it's recognisable as the logo, but as long as it looks like a monkey, it'll do the job.
Mr L, I've been collecting together small weddling jobs for you to do -I've left a list on the bonnet!
He's only playing for sympathy you know.  Tongue
The larger size.
steve brock
« Reply #4222 on: January 13, 2012, 11:41:03 PM »
Your profile pic monkey.. I can scale to anysize you want! Want me to fire over a 1:1 scale you can print them to see which looks the right size.. Smiley I'm quite nifty at lettering too if you need some letters "mankys pop" for example in 3mm..
« Reply #4223 on: January 14, 2012, 12:01:06 AM »
Just the head will do nicely thanks!  Smiley
« Reply #4224 on: January 15, 2012, 10:17:23 AM »
An afternoon of ticking off small jobs yesterday. Loony was back at the 'shop, so he began working through my pile of small welding jobs, adding mounting tabs here & fill-in patches there. As each piece was done I cleaned it up with a softpad on the angle grinder. Nothing worth photographing, but it all needed doing.
I won't be there for the next few days as I've got things to do at home, but have left Loony with the shortened list -mounting flanges for the gearbox tunnel, tabs for the next dashboard panel & some stainless welding on the exhausts.
We had a look at the bonnet badge idea. Wasn't sure he'd like it but it got the Loony seal of approval. I wanted it big enough to show all the detail & to fill the blank space on the grille shell, while he preferred the smaller size as it was more subtle. I've had a word with Steve Brock about lazer cutting one of each so we can compare.
steve brock
« Reply #4225 on: January 15, 2012, 05:20:11 PM »
I have time tommorow lunch time to draft the monkeys heads will email ya the drafts 3 mm should be plenty thick enoughhave you thought about clear acrylic sheet as a material?
« Reply #4226 on: January 15, 2012, 11:10:38 PM »
Plastic?!! Thanks, but no thanks Steve. Steel's real but plastic's fantastic, not in keeping with the overall ethos of the vehicle.
steve brock
« Reply #4227 on: January 16, 2012, 06:23:40 PM »
Are all postmen perfectionists ?! Jaysus
phunkie hiboy
« Reply #4228 on: January 16, 2012, 07:38:21 PM »
So, how's about a proper one then?
Check these people out ...............
http://badgecraft.co.uk/
I've seen some of their stuff and it's all good   Grin
« Reply #4229 on: January 16, 2012, 08:45:31 PM »
Already being sorted Chris -hence Steve's jocular "Jaysus" jape.
