May 20, 2024, 11:49:38 PM *
Pages: 1 ... 266 267 [268] 269 270 ... 791
Author Topic: Manky's Pop.  (Read 1567231 times)
« Reply #4005 on: October 27, 2011, 08:50:44 PM »
did you use a differant dizzy the one i sent used ordinary points not cartridge or cassete type Undecided
« Reply #4006 on: October 27, 2011, 09:03:57 PM »
Ordinary points Mike, but they can't be seperated from their base plate cos the pivot pin's rivetted over, so the points themselves can't be slid off.
The distributor drive also drives the oil pump, so we had to take the drive from the bottom of the Mallory dizzy & adapt it to fit your one. Worked nicely.
« Reply #4007 on: October 27, 2011, 09:06:37 PM »
i had them points appart the other day  Roll Eyes
« Reply #4008 on: October 27, 2011, 09:36:50 PM »
Ah well, we'll bung a new set in anyway mate. I really appreciate you sending the dizzy down. Mallory dual point set-ups are supposed to be the best you can fit, but we had endless problems with our particular one. I know I'm a mechanical dunce, but at least with your fully mechanical jobbie fitted, I stand a chance of a roadside bodge if it ever packs up.  Grin
« Reply #4009 on: October 27, 2011, 09:39:50 PM »
if you put spare points and condensor in the glove box  youlle never need them Wink
« Reply #4010 on: October 27, 2011, 09:54:04 PM »
 Grin That's the plan! -except I haven't got a glove box.
« Reply #4011 on: October 28, 2011, 06:04:28 AM »
stick a box full in the bed!!!!
« Reply #4012 on: October 28, 2011, 07:29:03 PM »
another sva build, just been in for test.
http://www.rodsnsods.co.uk/forum/garage/my-model-money-pit-32170
« Reply #4013 on: October 28, 2011, 10:11:55 PM »
Yup, that's Gav's model A. Of the ones we know of, racing to beat the test deadline, no-one's passed first time yet.
« Reply #4014 on: October 29, 2011, 12:03:48 PM »
LOOK WHAT I FOUND   http://youtu.be/z0RTqZDSuDU
« Reply #4015 on: October 29, 2011, 07:05:26 PM »
Apologies Spanners , they did indeed come part today but required a bit of effort  Embarrassed
« Reply #4016 on: October 29, 2011, 07:16:45 PM »
no worry,s  i can remember when we,ve been at the track and had to make up a set of points from 3 or 4 knackered sets just to get on the starting grid
NeilG
« Reply #4017 on: October 29, 2011, 07:47:30 PM »
Been  emptying the garage today ready for moving,too late now but found the starter motor..........all 3 of them lol.
« Reply #4018 on: October 29, 2011, 08:13:39 PM »
Neil have you got an alternator in your garage Andy could borrow. so we can test the wirering
« Reply #4019 on: October 29, 2011, 09:08:02 PM »
bit of a small set back today.me and Kev went to sort the starting out on pop.Kev changed the points. i connected the fuel line as the pump got moved.all done started up ticked over set dwell.timing tweaked carb all good so far. then it started to smoke a bit and the cam lifters started to rattle.and it got hot.
checked out the water level was low topped up started up again no still getting to hot. checked fan no power. so hot wired it topped up the water again and started it back up.we let it run for about 20min it seamed fine.just got to find out why it lost power for the fan.but at least it is running sort of ok now just needs fine tuning. were getting there. Kev will be sorting out the brake pressure. now it will tick over and run
