May 20, 2024, 09:04:45 AM *
Pages: 1 ... 119 120 [121] 122 123 ... 174
Author Topic: Manky's XS650 Yamaha  (Read 554633 times)
« Reply #1800 on: February 03, 2017, 07:01:02 PM »
While I nipped across town to fetch some gasket sealant from my other garage, Bob, (BayChimp), tackled the alternator brushes.
Looks like he may have found the charging problem. One of the brush wires had come adrift from it's mounting plate. The new ones I bought are supposed to be universal & fit either side of the housing, but don't appear to. Fortunately the broken one was the same as the new ones, so we fitted one new & one, (still intact), old one with plenty of life left in it's brush. Now I need to charge the battery -yes, I forgot to do it -so we can start it up again to check the charging. I've still got Mr Olds' multimeter, left behind when he was working on my truck's wiring, but haven't got a clue how to use it to check the battery's charging.
« Reply #1801 on: February 03, 2017, 07:15:36 PM »
I've really had trouble working up the enthusiasm to work on this thing lately, so big thanks to Bob for giving up his afternoon to give me the push I needed.  Wink
After he'd left I got back to the exhaust baffles. I've gone with the longest length of perforated tube I can fit in the pipes, which is 30". That means welding 2 sections together. I've also cut down the reducing sleeves to form plain collars at each end. Had to slit them down the side & pinch them in until they fitted the pipes. I've already ordered some basic baffle wadding from Ebay, which comes with stainless cable ties to hold it in place around the tube. Just hope there's enough room between the pipe & the baffles to use it. Oh yeah -the missing parcel containing the first lot of perforated tube turned up today. Seems it had been left next door, tucked in front of the owner's car. He's in his 90s & very unwell so hasn't used the car for a long time. The parcel only came to light when his daughter put the car in his garage for him this morning. The tube was posted a month ago.
I had a few errands to do later this afternoon, so nipped over to see Leia the welder in Berkshire & left the sections with her for stainless welding. Glad I did cos her Dad was there. He used to own the company & handed it to his daughter when he retired to France. He's over for a holiday & I hadn't seen him for years.
« Last Edit: February 03, 2017, 07:23:00 PM by Manky Monkey » Logged
« Reply #1802 on: February 03, 2017, 07:23:11 PM »
So baffles underway. Charging problem hopefully fixed. Clutch hopefully fixed.
I've got to make a new front panel & mounts for the battery box, get the rear indicator mounts welded to the mudguard strut, wire them in & also wire in the new fusebox, then get a few bits re powder-coated. I think I'm going to leave the anchor arm on the rear brake caliper as it is for now & also leave the rear brake pedal set-up well alone. Needs a new LED in the speedo, just cos it's blue & I'd like green & the tank paintwork has a run & a couple of specks of grit in it that need sanding out & polishing. Think that's about it.
I'll charge the battery over the weekend & we can try firing it up again early next week. What could possibly go wrong?  Tongue
« Last Edit: February 04, 2017, 08:28:52 PM by Manky Monkey » Logged
flc
« Reply #1803 on: February 03, 2017, 11:32:43 PM »
Am exited for you, bike looks lovely. Really nice,  soon be buzzing about on it just as it's starting to get warmer
lunatic
« Reply #1804 on: February 04, 2017, 12:09:44 PM »
Dropped toms frame off at the coaters yesterday, the race is on!  Grin
Dslam
« Reply #1805 on: February 04, 2017, 03:28:22 PM »
Excellent news. It cannot be far away from rideable Roll Eyes
Looking forward to seeing it running and riding.
« Reply #1806 on: February 04, 2017, 08:24:51 PM »
As soon as it's roadworthy, you'll be first on my People to Visit list Andy Smiley
I was in the same road as you yesterday then Mr Loon. I'll sort out a small pile of weldy bits & come visit soon.  Wink I suspect Archie might beat us both!
« Reply #1807 on: February 08, 2017, 07:21:34 PM »
Exhaust wadding's arrived. Just waiting for the baffles from the welders now.
Baychimp
« Reply #1808 on: February 08, 2017, 10:21:50 PM »
Get those sorted,and the battery charged and we'll have a go at starting it.
flc
« Reply #1809 on: February 09, 2017, 09:28:30 AM »
"Sounds " like good progress on the baffles  Grin
« Reply #1810 on: February 09, 2017, 07:11:21 PM »
 Cheesy Battery charged. Tom's collecting his XS frame from the powder-coaters tomorrow, so dropping off my indicators at the same time.
I'll have a few other parts to be done later.
« Reply #1811 on: February 10, 2017, 09:32:15 PM »
Dashed over to Berkshire in the first snow flurry of the Winter, after work this afternoon. The welding shop owned by Leia, (named after a certain Princess in a Galaxy far, far away), closes early on Fridays & she'd rung to say my baffles were ready. They shut at 4.45 & I arrived at 4.44
A tidy job -& they appear to fit too, which is nice. The white stuff's the wadding. I'll only have room for a few millimetres of it around the perforated baffles, but figure some's better than none.
« Reply #1812 on: February 10, 2017, 09:38:27 PM »
As I was leaving the welder's, Scott the engineer, (one time forum member Captain SaddleBags), rang to say my kickstart lever was done & he'd be at the workshop for a while longer before taking a few days off. So I had to dash back to Hampshire in the evening rush hour to reach him before he went home.
Nice job. He's drilled the 2 halves of the pedal & pinned them together, then cross drilled them, so a bead of weld can be run around the middle & the ends of the pin can be button welded too. Belt n braces cos I don't want to jump on the lever & have it snap off.
Old, standard pedal, powder coated black & replacement, modified one, which will also be coated black.
« Reply #1813 on: February 10, 2017, 11:27:29 PM »
Oddly, I would have said the new rubber should be the other way 'round?
« Reply #1814 on: February 10, 2017, 11:29:00 PM »
"Oddly", Manky's new name - yeah, it suits!!  Grin
