May 20, 2024, 07:38:35 AM *
Pages: 1 ... 24 25 [26] 27 28 ... 174
Author Topic: Manky's XS650 Yamaha  (Read 554621 times)
« Reply #375 on: November 18, 2012, 07:31:52 PM »
Never leave Loony in charge of your camera.
« Reply #376 on: November 18, 2012, 07:33:17 PM »
« Reply #377 on: November 18, 2012, 08:50:13 PM »
Decided to quickly chuck the motor back in the frame to check the carb clearance. Quickly chuck it in -ha!! Big Darren & I struggled with it for over an hour & got absolutely nowhere -except he managed to pinch his big fingers between the engine & frame.
You did say that it was a tight fit. Seems like I left at the right time Cheesy
Shame it's got to come out again, but the carbs and manifolds look just right.
« Reply #378 on: November 18, 2012, 09:09:03 PM »
Nice to see you today Dave.
Cabman77
« Reply #379 on: November 24, 2012, 01:26:11 PM »
haven`t had a chance to look for the cable doowidgey thing yet, had some domestic issues in the past couple of weeks. But i will do it soon I promise.
If my memory serves me well XS650 lumps were always a bugger to get back into the frame. I`ve done a lot of work on them in the past and every single one was a struggle and half to re fit in the frame. I thing it`s because the frame is such a rigid structure compared to other jap frames that flex like spaghetti. I have had to jack the bottom frame rails out (less than 1mm!!!!) to get a lump in, and that was after I stopped the owner from trying to drill the mounts out to get the bolt through!!!!!! Wherever possible I laid the lump on it`s side and lowered the frame over it. Partly because the frame is a bit lighter and easier to handle but also gave us the option of seeing what the frame needed to do to fit. Every one was different, never had two the same and I must have done about 10 of them!!!!! Shocked Shocked Shocked Shocked
« Reply #380 on: November 24, 2012, 06:54:21 PM »
Yup, standard way of fitting a Sportster engine is frame over engine I believe. We tried that too. Can't even strip the motor down then build it up in the frame cos there's not enough room to get the head off.
Nothing worth photographing, but I spent the afternoon yesterday messing about with the rear mudguard & struts.
Just filling in time until the truck door hinge parts arrive from soggy Somerset.
« Reply #381 on: November 30, 2012, 10:25:21 PM »
Loony's been having a practice on his Dad's lathe & turned these 10mm thick stainless collars from a length of round bar blagged from Doug of the Guzzlers car club. Loony Senior then milled the slots in them. The threaded mounts weld to the frame & the collars sit over the rear wheel spindle. Undoing the lock nuts & winding the bolts through, pushes the spindle backwards to tension the chain.
« Reply #382 on: November 30, 2012, 10:30:38 PM »
I bought a pair of 600 series Amal carbs for the bike over a year ago, then discovered I actually needed the bigger 900 series. So I picked up a pair of empty carb bodies on Ebay. There was some cash in my PayPal account from recent merchandise sales, so I've invested it in all the needles, jets etc I need. Fortunately the guy who sells the cast aluminium carb manifolds on Ebay listed the jet sizes needed to run with the XS motor.
Every piece arrived sealed in it's own individual Amal bag. Even the new throttle slides came in tiny little cardboard boxes.
On the left are the 3mm thick heat insulating gaskets, recommended by Dslam.
« Last Edit: November 30, 2012, 10:32:47 PM by Manky Monkey » Logged
« Reply #383 on: November 30, 2012, 10:41:42 PM »
Looks like you've got a couple of fun hours assembly time ahead of you. At least this you can do inside in the warm Cheesy
« Reply #384 on: November 30, 2012, 10:47:01 PM »
Yeah, I was going to bring them home to do this evening, but the new tickler buttons are on roll pins, with the ends splayed to stop them pulling out of the carb body -so I'd need a hammer & punch to fit them. Less hassle to do at the workshop!
« Reply #385 on: November 30, 2012, 10:52:58 PM »
I'd do as little as possible at the workshop. Grinding dust and new carb parts etc. etc. Wink
« Reply #386 on: November 30, 2012, 10:56:24 PM »
 Smiley They're my job for tomorrow. Saturdays are always busy with lots of visitors to the 'shop, so I'll find a quiet corner of a bench to build them, then fit them back on the engine & seal them with some plastic bags.
« Reply #387 on: December 01, 2012, 09:58:43 PM »
Another late day at the Post Office, (it's beginning to look a lot like Christmas). Trudging the streets in the freezing cold. So not a lot of time at the workshop today. Especially with a visit from Uncle Kev, (Kapri in his gorgeous new motor. See the Fury -ous thread in General Discussion).
Managed to fit the new float bowl priming pins though.
These are supposed to stop fuel seeping out & soaking your fingers when you prime the carbs. Must admit though, I just bought 'em cos they're shiny.
They're spring loaded buttons that push the fuel float down, filling the float bowl prior to starting the engine.
I've got an extended tickler.
« Last Edit: December 01, 2012, 10:00:44 PM by Manky Monkey » Logged
« Reply #388 on: December 01, 2012, 10:05:52 PM »
As good a reason as any!   Smiley
« Reply #389 on: December 03, 2012, 11:03:43 PM »
Chain tensioners welded to the axle plates. I'm leaving all the frame welds till we're done, then will clean them all up in one go.
« Last Edit: December 03, 2012, 11:05:24 PM by Manky Monkey » Logged
