May 08, 2024, 10:21:45 PM *
Pages: 1 ... 10 11 [12] 13 14 15
Author Topic: look at what i have been given  (Read 52317 times)
« Reply #165 on: April 07, 2018, 08:04:04 PM »
Merv how are you going to attaché the new swing arm to this. apart from just  welding.
« Reply #166 on: April 07, 2018, 09:21:54 PM »
 Hi Terry, Have you something in mind, the original arm's were only welded on, all i did was cut them off and cleaned up the welds ready for the new arm's.
« Reply #167 on: April 09, 2018, 08:46:59 PM »
I would have left the swing arm as it was and just cut part of the shaft tube away as required .
That way it would have given a lot more metal left to graft and weld the new rails to.
« Reply #168 on: April 10, 2018, 10:59:18 AM »
Well onwards it is then Merv  Roll Eyes
« Reply #169 on: April 10, 2018, 03:29:53 PM »
Well we'll give it a go Smiley
« Reply #170 on: April 26, 2018, 08:18:14 PM »
Anymore progress on the swingarm Merv?
Living on a wing and a weld
« Reply #171 on: April 27, 2018, 04:06:50 PM »
Not just yet Paul, iv'e  been to busy. Still playing with the electrics. trying to figure where i can put the relays and stuff.
« Reply #172 on: April 28, 2018, 10:33:54 AM »
Have you thought about relocating relays to rear cowl, loads of space in there and should be straight forward to run a wiring loom to there from the front.
I think my hazard relay is in the rear cowl along with another.
« Reply #173 on: April 28, 2018, 11:22:49 AM »
Get it on three wheels then sort the wiring and other bits out.
« Reply #174 on: April 28, 2018, 12:27:09 PM »
That's what i'm thinking Paul, yes Terry, sorry Terry. I'm just doing bits when i got five. I will start the swing arm when i have a few days off in a row.
« Reply #175 on: April 28, 2018, 01:06:53 PM »
you could use male spade connectors at front end, back to females at the rear.
« Last Edit: April 28, 2018, 02:59:40 PM by paulywombats » Logged
« Reply #176 on: April 28, 2018, 04:49:46 PM »
The battery i'm using is a sealed unit, could i mount it led down on its side ? Also i have fitted l.e.d. front indicators, they flash with the backs which is bulb but they flash rather fast how can i slow them down. When using the hazard switch they flash at normal speed .
« Reply #177 on: April 28, 2018, 07:13:27 PM »
I would check that you have a good negative connection for the flasher relay, since the hazard relay is working correctly. Failing that you may have to replace flasher relay for one that operates with any mix of lamps i.e led and filament . These are readily available for around £8. I think yours will be a three pin. Car builder solutions are good people to speak with for advise.01580 891309.
Have you just replaced front bulbs in the original light units or are they replacement units?
As for battery, it does depend on internals. If it is a carbon mat type, then yes you can lay it in any orientation, even upside down. Most sealed, maintenance free batteries, still need to operate in the upright position.
Take advise from the battery manufacturer or supplier.
« Last Edit: April 28, 2018, 07:50:21 PM by paulywombats » Logged
« Reply #178 on: April 29, 2018, 02:13:18 AM »
The front indicators are replacements
« Reply #179 on: April 29, 2018, 08:16:43 AM »
This is the battery i have, it's a gel type one, so i believe i can lie it on it's side, would that be correct
 https://www.ebay.co.uk/itm/Nano-Gel-Upgrade-Battery-HONDA-ST-1100-Pan-European-89-02-Replaces-YTX14-BS-/251437711069?hash=item3a8adafedd
