can anyone with a temp gauge fitted to there reliant engine or if you just know because your clever tell me what the temp should be around when its fully warm on a run?? mines reading around 100c ish its had a full rebuild with new pistons/liners so will be tight maybe running at the higher temp,but it seems a little to high to me??
Hi O A B. looking in the work shop manual. the stat starts to open at 85/89c and is fully open at 103c. so your not far out at 100c ish
