DIZZY
Ride it like you want it
« on: March 24, 2011, 08:13:20 PM » |
Can any one point me in the right direction? I've just attempted to bend my first tube,1" n half with 3mm wall and its squashed it giving a flat spot.
Whats the general rule ? thought I'd ask rather than waste any more tube.Am I doin some thing wrong? saw a guy on youtube filling the tube with sand first .
Dizzy
zakboy
« Reply #1 on: March 24, 2011, 08:16:33 PM » |
are you using a tube bender or a pipe bender, i have used damp sand in thin wall tube but have no brob bending 3mm wall
« Last Edit: March 24, 2011, 08:32:00 PM by zakboy »
dobber
« Reply #2 on: March 24, 2011, 08:30:07 PM » |
had same prob, guy who lent me the bender said i had the pins too far apart. sometimes it bend good, others had a flat spot, never got hang of it. was same 1inch 3mm tube
DIZZY
« Reply #3 on: March 24, 2011, 08:52:10 PM » |
Its the normal clarke 12ton bender
Dizzy
DIZZY
« Reply #4 on: March 24, 2011, 09:01:27 PM » |
Wots the difference between tube and pipe?
Dizzy
zakboy
« Reply #5 on: March 24, 2011, 09:14:55 PM » |
iv never bent any tube that smaller diammiter, but if i have any knocking about will have ago tomorrow see if i have a prob, if i do i know just the man to go and ask, will let you know, i presume you are using the correct size former
« Last Edit: March 24, 2011, 09:17:34 PM by zakboy »
« Reply #6 on: March 24, 2011, 09:54:27 PM » |
The Clark bender is for bending pipe, You say your tube is 1in is that the internal dia or external dia If it's 1in internal it's pipe if it's 1in external then it's tube.
« Reply #7 on: March 24, 2011, 10:02:48 PM » |
Hi hunter. i think he said the tube is 1 1/2" Can any one point me in the right direction? I've just attempted to bend my first tube,1" n half with 3mm wall and its squashed it giving a flat spot.
DIZZY
« Reply #8 on: March 24, 2011, 10:21:55 PM » |
Yes its 1" n half out side diameter or 32mm,used 32mm former wanted 90 degree bend but as i say ,started to squash and flatten.
Dizzy
zakboy
« Reply #9 on: March 24, 2011, 10:26:37 PM » |
i miss read it i thought it was 1 inch, if its inch and half, i bend 1.1/4 inch with out any probs, if its 32mm its not 1.1/2 are you sure you are not trying to bend 32mm in 1.1/2 former as that could acount for your prob,zak
« Last Edit: March 24, 2011, 11:44:11 PM by zakboy »
« Reply #10 on: March 24, 2011, 10:42:06 PM » |
Hiya. We use 1" bore heavy gauge ERW for trike frames. Basic, red oxide painted "steam pipe". It's 1 3/8" outside diameter, so about 4.5mm wall thickness. Quite easy to bend, but works well in a properly triangulated trike frame. It bends nicely in a normal Clarke 12 ton hydraulic bender. I set the rollers on their middle position, (I think there's 6 positions so they're on the third holes), & use the forming head marked 1". I don't usually have to bend more than 90 degrees, but it does that with no problems. I'd suggest maybe you're using too thin walled tube, pipe.
trev
« Reply #11 on: March 26, 2011, 08:59:20 AM » |
i,ve used my clark 12 ton bender for the past 5 years on all sizes of pipe-tube and never had the slightest problem,great bit of kit.
DIZZY
« Reply #12 on: March 26, 2011, 09:14:26 AM » |
Hi all,think ive sorted the problem.I filled the tubes/pipes with building sand,taped the ends up with gaffa tape and it bends no problem.
Will put some pics on soon.
Dizzy
Daddy Bear
The older i get the faster i waz
« Reply #13 on: March 26, 2011, 10:51:49 AM » |
and ive watched TREV DO IT CUZ I DON'T WANT TO GET MY BENDER DIRTY HE HE
blair
it looks bigger in water ! !
« Reply #14 on: March 28, 2011, 10:41:26 AM » |
glad to see your given it as go Dizzy . look forward to seeing your progress
