May 09, 2024, 02:49:52 AM
General Tech
Angle grinder
Topic: Angle grinder (Read 2099 times)
klogan45
Angle grinder
February 29, 2016, 07:11:28 PM »
So......... had the big angle grinder out a couple of days ago all was well until I had to change the disc.
The flippin thing would not come off. The c spanner bent and the jaws of the spanner that I had on the back, clamped in the vice, snapped.
So....... I had to break it ft the disc, take off the guard, undo the 4 screws that hold the drive gear, put the shaft in the vice. I welded the c spanner to a nice chunk of 25mm box section and was then able to undo the retaining nut thing.
Can anyone tell me why the disc was on so tight. When I put the disc on I only tighten finger(ish) tight cos I found that if I used the c spanner to tighten it I can't get the disc off.
Advice/ info greatly appreciated.
Re: Angle grinder
February 29, 2016, 07:49:02 PM »
Because of the direction the disc travels it self tightens,
The more pressure you put on it the more it tightens,
Also if it jams and jolts it tightens even more.
Sid_Vicious
Re: Angle grinder
February 29, 2016, 07:55:33 PM »
That's my experience to, it can be a bugger to undo again sometimes.
Bus Boy
Re: Angle grinder
February 29, 2016, 08:47:31 PM »
Yep had the same problem meself a few times. Seems to happen more often if I'm cutting masonry (concrete slabs). I believe this is because the disc jumps & jolts about a lot more so it tightens the lock nut.(as Mr Hunter just mentioned)
I found that a pair of tight mole grips on the lock nut and a sharp hammer blow normally sorts it out or a set of stilsons will do it. Saves all the stripping down.
klogan45
Re: Angle grinder
March 01, 2016, 07:27:42 PM »
Thanks guys, glad to hear that it's not just me.
