Here we are some way though another project, similar to the last one, but different!!
Similar, ‘cos it’s a Radio Flyer, but different ‘cos well it’s not the same.
Got this off eBay a couple of months ago, Bit beaten up, but can be rescued.
Anuvver Phunkie flyer
So this one will have a separate chassis, we’ll start by making a rear axle. Turn up a couple of spindles (just happened to have some EN8 steel).
Press them into some 7/8” tube.
One small rosette weld through the tube into the spindle on both sides where it won’t be seen.
Spindles drilled and tapped down the end to secure the hubs.
Now we have a rear axle, fit some wheels and tyres and a quick mock up to see how they look.
Now onto the rest of the chassis. Cut to length 7/8 tube as required.
Using a real basic set of plumbing pipe benders, curve up parts to pre determined angles.
Start tacking the frame together.
We’re using go kart front spindles (that will require modifying), as can be seen in this picture, together with a small dropped tube axle.
Mock up with the body on.
Body off and fully weld frame, fit body mount brackets and a steering pivot at the front.
This is all stripped down now and the chassis and modified (longer) pull handle delivered to the powder coaters this morning, should be ready Thursday morning.
