May 09, 2024, 03:12:00 AM
General Tech
Another embarassing question!
Topic: Another embarassing question! (Read 2344 times)
December 15, 2012, 11:07:09 AM »
What is the length of the Reliant 850 dipstick?
Please could someone with a Reliant 850 engine, measure the dipstick from the flange to the high or low marks.
Sounds stupid I know but I modified mine, thought I got the length the same but after filling with exactly 5.5 pints, find the level is not quite reaching the low mark
one arm bandit
Re: Another embarassing question!
December 15, 2012, 11:30:49 AM »
354mm to the high mark 365mm to the low mark, thats measured from the flange (big circular bit/stop) on an unmoddifyied dip stick
December 15, 2012, 01:08:04 PM »
Thanks a lot OAB
Doh! Too short by 30mm. How the f### did that happen. Didn't cut anything off
Expected maybe 5mm short max
At least now I can sort it.
Last Edit: December 15, 2012, 01:14:29 PM by Old Newbie
December 15, 2012, 07:15:24 PM »
I got extremely confused when I cut my dipstick down,then tried replacing it. From memory,I dont think it actually goes to the bottom of the sump(ie doesnt 'bottom out')
one arm bandit
December 15, 2012, 07:48:59 PM »
no your right rod its about 40mm ish from the bottom, i know when you asked the same question, was the same time my engine was in bits on the kitchen table so i measured this for you, and have it wrote down on my build paper scraps somwhere?? i found it better to do the oil and filter then add exactly the 3.4l or whatever it is of oil and remark the dipstick to the oil level, like i say mines unmodded but the marks wernt very neer after adding the required oil.
December 15, 2012, 10:10:19 PM »
Quote from: one arm bandit on December 15, 2012, 07:48:59 PM
I have now done just that. Easier than trying to lengthen the dipstick
