Title: A bit of Reliant info needed Post by: brock on November 13, 2013, 08:19:49 PM Anyone in the position to take a couple of measurements for me ?
I need to know how much throw I need to build into the clutch pedal , how far does the clutch lever on the box need to move ? either in degrees of rotation or horizontal movement and lever length . Hand brake , how far does the lever on the backplate need to move . Any and all info gratefuly recieved , thanks Title: Re: A bit of Reliant info needed Post by: Olds on November 13, 2013, 09:01:47 PM Clutch arm = 147 between centres, normal movement =35mm, movement required to disengage clutch =17 to 20mm approx.
Handbrake arms movement will depend on adjustment but mine are about 4 to 5mm at clevis. Hope this helps. Title: Re: A bit of Reliant info needed Post by: kapri on November 13, 2013, 10:15:33 PM Normal clutch pedal ratio is around 4 or 4.5:1 ,same as standard automotive brakes.
Title: Re: A bit of Reliant info needed Post by: brock on November 13, 2013, 10:17:32 PM Spot on , thank you both
