May 16, 2024, 11:03:01 PM *
Author Topic: kwaker gpz 900r ,  (Read 1986 times)
tony b
« on: December 01, 2009, 09:37:14 AM »
got the bike goin yesterday ,i turned out to be coils ,i also fitted it with new leads,problem is ,when i first start her up she is sucking air and i have to leave it for a few mins until it warms up before i can twist the grip.once its warmed up its fine ,it is fitted with K+Nfilters
gsxrsam
« Reply #1 on: December 01, 2009, 06:38:11 PM »
running lean so needs richening up or one of inlet rubbers is cracked..  thats  were id start.
tony b
« Reply #2 on: December 01, 2009, 09:25:46 PM »
how do i richen it up
Basket case
3 wheels on my wagon...
« Reply #3 on: December 02, 2009, 01:44:20 AM »
Stuff a grand in used £20s under the seat  Grin Grin
toad
« Reply #4 on: December 02, 2009, 06:08:11 AM »
get a stage 1 dynojet kit not cheap but tha,ll sort that problem out  Wink
gsxrsam
« Reply #5 on: December 02, 2009, 07:06:27 AM »
first check rubbers on carb inlets for cracks, do this by spraying wd40 around rubbers and if engine note changes it is letting in air and needs repair or replace of inlet rubber/s.
if ok, i would screw in pilot screw 1/4 turn and see if  starts better,checking plug colour is good idea at tickover is good help, u want digestive biccy colour, milky bar colour is lean and bad, choccy covered digestive colour is running rich..  run it for min or two with choke off and check...
also make sure choke is working fully..
tony b
« Reply #6 on: December 02, 2009, 01:29:39 PM »
ive only got ,rich tea,hob nobs and custard creams in at the moment ,ill check the plugs after ive been shopping,cheers mate,
gsxrsam
« Reply #7 on: December 02, 2009, 01:56:13 PM »
hob nobs is good colour  Grin
tony b
« Reply #8 on: December 03, 2009, 01:40:54 PM »
ok then ,the bike stops sucking air after 2000 rpm,but when i switch it off the is still smoke commin out of the right hand exhaust,and when running it comes out of the right hand pipe more than the left.HELP PLEASE,
gsxrsam
« Reply #9 on: December 06, 2009, 08:37:23 AM »
i would suggest balancing carbs......  you are moving onto needle above 2000 revs so different mixture setting from pilots...
pilots are the screws that usually go vertical on carbs, usually in a hole under carb behind float bowl.. have it running and screw in quarter/half turn see if it smooths out...
