« Reply #15 on: September 21, 2011, 09:49:33 PM » |
Thanks Morrag! Possibly the one in Loony's workshop may be closer tho, I can't remember where you are (you're not on the Manky Monkey Map!) I know it sounds like a lot of work but how about disconnecting the propshaft to tow the trike. No cos I need to be able to take it off the trailer and ride it without major engineering!
« Reply #16 on: September 21, 2011, 10:08:48 PM » |
hi, B,G, i know most trailer law/rules but there not easy to explain.. try googling ,,towsure,, they used to have an information section
Cheers Spanners - they do and I've bookmarked it! Just what I needed.
« Reply #17 on: September 21, 2011, 10:24:33 PM » |
Basingstoke, Hampshire Bobbi -the centre of the trike building universe.
« Reply #18 on: September 22, 2011, 01:03:45 PM » |
Thats the Tow a Trike isn't it Morrag? I borrowed on that looked very similar off Hightower to get my VW trike back from other side of Grantham. Brilliant bit of kit and I keep meaning to get one made up.
kevsky
« Reply #19 on: September 22, 2011, 02:26:40 PM » |
I have one of these it came with the trike brillant bit of kit if anyone needs dimensions just ask
« Reply #20 on: September 22, 2011, 04:41:37 PM » |
i got one as well there called trail a trike they were made by the guy that had the National trike register Webb site site just went rummer has it that one of these snapped an he is being sued
« Reply #21 on: September 22, 2011, 08:27:03 PM » |
don`t really like to think that I would use one of them. They do look a bit flimsy to me.
This still wouldn`t solve Bobbi`s aouto box problem though.
snafu
« Reply #22 on: September 22, 2011, 08:42:09 PM » |
If the auto trike has a mini engine it can be tow'd with drive wheels on the road, the transmission has two oil pumps, one the engine pump that also feeds the transmission and a front pump located behind the speedo housing this lubes the trans when towing. originally the second pump was fitted so the mini could be tow'd behind large camper vans in the USA.
« Last Edit: September 22, 2011, 08:54:09 PM by snafu »
« Reply #23 on: September 22, 2011, 09:55:44 PM » |
I'm impressed with your level of useless information retention Sir!
« Reply #24 on: September 23, 2011, 12:54:27 PM » |
The one I borrowed off Hightower is a solid enough lump Cabby. It has been used to tow quite a few trikes now including HT's desperate dan V8 and I haven't heard of any problems. Going to get a copy done myself as it does seem the guy that made them has vanished. Best bit is they easily fit in the boot of a car so no storage problems. It does rely on having all three wheels on and capable of turning and wouldn't solve the auto problem for Bobbi though
« Reply #25 on: September 25, 2011, 06:29:02 AM » |
Hi Bobbi
The maximum authorised mass of the trailer must not exceed the unladen weight of the towing vehicle for a normal car license. upto a combined MAM of 4.25t unless you have B+E.
With a trike on the Trailer I'd want a braked trailer.
Make sure the trailer is in good working order and your towbar has the manufacturers plate etc
« Reply #26 on: September 25, 2011, 07:35:45 PM » |
Yes I've thught of one of those but it wouldn't be any good for moving the auto trike.
it would if you unbolted the propshaft
« Reply #27 on: September 25, 2011, 08:57:56 PM » |
I found a card of some nice people that got me right out of the sticky brown stuff a few years ago Bobbi. I know they`re a bit of a way from you but might be worth a chat. The Guvnors name was Neil Bolger, hope it helps.
A.N.Fabrications The Old Airfield Hospital Mendlesham Airfield Town Lane Brockford Stowmarket Suffolk IP14 5NF
01449 767821
« Reply #28 on: September 26, 2011, 06:39:22 PM » |
Cheers Cabman - too far really!
