« Reply #195 on: January 12, 2016, 08:22:40 PM » |
Merv. Do you know anyone traveling in my direction, I'll weld it in for you.
« Reply #196 on: January 13, 2016, 06:58:00 PM » |
Thanks hunter I don't know any one traveling your way but PM me your address and if I think its near enough and its alright with you I'll bring it up myself on a Saturday, it would be good to meet
« Reply #197 on: January 13, 2016, 09:52:38 PM » |
What time are you thinking Merv.
« Reply #198 on: January 14, 2016, 07:04:56 AM » |
Would I have to seal the threads that the bolts go through into the tank, also on the original tank the mounting ring is welded to the outside of the tank with threaded holes that don't go through the tank, the sender unit is bolted to the ring with a seal. So if I cleaned up the original mounting ring and used it on the outside with your idea of a split ring on the inside what would be a good material to use as a seal between the tank and the outside mounting ring.
Yep, the threads or bolts would have to be sealed. Nitrile rubber gasket material is sold for fuel tanks. Having someone capable like hunter weld it in would be the better way to go if you can. I only put forward possible alternatives as you seemed reluctant to weld the tank.
« Reply #199 on: January 14, 2016, 06:35:39 PM » |
You are so right Dave, I am reluctant to set to on my petrol tank with the mig, been speaking to hunter and I'm going to take the tank to him he's going to bronze weld it
« Reply #200 on: January 23, 2016, 09:04:20 PM » |
Well, went on a road trip today down to hunter's with my petrol tank took me just under two hours to get there. Went to his lock up, not what I was expecting, he has an Aladdin's cave. What a nice fella, I reckon there was about an hour to hour and a half of work done and the rest talking. he cut a hole in my tank then welded the fuel sender unit in, now I have a tank with a fuel sender. Part from getting my tank done I met a another monkey. Thanks hunter for a good day it was good meeting you.
« Reply #201 on: January 23, 2016, 09:44:37 PM » |
No worries Merv, We've got to keep the monkeys going. Yep plenty of talking and some welder issues but got there in the end, And yes nice to chat and a great guy.
« Reply #202 on: January 23, 2016, 09:51:12 PM » |
The MMMotors match making service chalks up another success.
« Reply #203 on: January 23, 2016, 10:50:55 PM » |
The MMMotors match making service chalks up another success. Made me smile
« Reply #204 on: May 28, 2016, 08:28:03 PM » |
Just a little something, A before picture,
« Reply #205 on: May 28, 2016, 08:29:27 PM » |
the after picture
« Reply #206 on: May 28, 2016, 09:02:30 PM » |
Ooh! Shiny!
« Reply #207 on: May 28, 2016, 10:33:35 PM » |
Does that look like an aliens face ( screaming ) ?
« Reply #208 on: May 28, 2016, 10:54:28 PM » |
Is this the same tank your using ?
« Reply #209 on: May 29, 2016, 05:53:45 AM » |
the after picture
Very pretty Merv. What are you going to do for the timing mark ? MM knows a great engraver in Spain.
