Its been rescued up me unit thanks to big darren.
Pulled th battery out and it is pretty haggard from ending up upside down.
And the loom has had 2 wires cut through which run off out the fusebox and towards the coil, so guess that's why it had dropped to one. So hopefully an easy fix.
The battery tank box is pretty ruined and needs replacing. Even though I don't like them that much I think it will just get a square box on the frame rails at the bottom.
Then "loony"' is going to modify my tank for me to take an airline fitting as the standard tap is too restrictive and a high flow tap is well into the 100's. So once thats done if shouldn't starve the carbs anymore. I was a bit worried about not having an on/off switch but you can get inline fuel taps for about a tenner and that'll do the job nicely.
Just need to get holiday out the way and slowly start doing it I guess.
I'm also going to rewrap the pipes as well as possibly making them a bit longer with a couple of kickouts.
Archie's XS
