twisted
« Reply #30 on: May 29, 2014, 08:05:36 PM » |
nice one merv its started now, soon be done
« Reply #31 on: May 29, 2014, 08:19:13 PM » |
Lets hope nothing does go horribly wrong. Just be prepared for lots of, slightly wrong, or as I prefer, nearly right.
« Reply #32 on: May 29, 2014, 08:38:25 PM » |
Design deviations.
« Reply #33 on: May 29, 2014, 08:48:18 PM » |
In answer to hornet6 question I'm going to attempt a manky style frame, I like the simplicity of it . This has been so long in the planning I'm not going to rush at this. I'm a semi skilled cabinet maker and you know what the main saying is, measure twice cut once and I still get that bit wrong, so I don't know what's going to happen in this build but you lot will see the lot, warts 'n' all . I'm getting butterflies thinking about it. So I'm hoping you lot will calm me down and help me hold it all together .
« Reply #34 on: May 29, 2014, 08:51:39 PM » |
We'll hold your hand all the way Merv. Hope you've got room for all of us in your shed.
« Reply #35 on: May 29, 2014, 08:59:01 PM » |
Buy the pipe, cut to length, bend, swear, then go buy more pipe.
« Reply #36 on: May 29, 2014, 09:18:11 PM » |
« Reply #37 on: May 29, 2014, 09:25:24 PM » |
MMMotors -the pipe suppliers' friend.
« Reply #38 on: May 29, 2014, 09:46:43 PM » |
just take a deep breath and dive right in
saex69
« Reply #39 on: May 30, 2014, 10:16:19 PM » |
Great start Merv, i find when i need to take a break from the work shop is to take the dog for a walk helps the grey cells work and think things through and planing ahead.
« Reply #40 on: May 30, 2014, 10:34:06 PM » |
Started the engine inspection, cant shift the darn head
« Reply #41 on: May 30, 2014, 10:42:44 PM » |
another
« Reply #42 on: May 30, 2014, 10:43:54 PM » |
can you take out the dip stick tube ?
« Reply #43 on: May 31, 2014, 04:45:15 AM » |
Yep. Did you get the head off ? If not it might help if you remove the head studs (using two nuts locked together). Makes cleaning the block face easier later anyway.
« Last Edit: May 31, 2014, 05:13:24 AM by Olds »
« Reply #44 on: May 31, 2014, 07:45:48 AM » |
Thanks for that Olds, I give that a go on Sunday as I'm not around today
