Title: Mx5 IRS info ? Post by: stinkey on November 27, 2017, 06:32:01 PM Hi peeps,just thought I'd put this up for a fellow monkey..(MERV ) he's collecting parts for a trike build..and maybe using an mx5 Mazda rear axle? And I said if he uses a motorbike engine it's possible the rotation maybe the wrong way ? So any info solutions would be nice?
Title: Re: Mx5 IRS info ? Post by: toad on November 27, 2017, 07:25:45 PM I'm pretty certain it will rotate the right way. send Byzmax a pm as he used this st up on a previous build. ;)
Title: Re: Mx5 IRS info ? Post by: terry t on November 28, 2017, 08:18:05 AM It will also depend on the bike engine. Kawasaki you will have to turn the axle over Honda you don't. not sure on the others
Title: Re: Mx5 IRS info ? Post by: Olds on November 28, 2017, 08:43:55 AM Should be fine if Merv is still going for a Reliant engine/box. Nice compact, self contained, IRS, that has the advantage of having fully adjustable geometry. Just a shame that the coil over tops mount to the body and not to the subframe. Though I should imagine these would need changing for something slightly lighter and top mounts could be added to the frame.
Title: Re: Mx5 IRS info ? Post by: stinkey on November 28, 2017, 06:50:23 PM He's got a bike he may use ? Maybe a conversion ?
