May 14, 2024, 10:25:08 PM
General Tech
Wide Moggy Minor Wheels
Pages:
Topic: Wide Moggy Minor Wheels (Read 5155 times)
Re: Wide Moggy Minor Wheels
Reply #15 on:
September 28, 2012, 07:51:30 PM »
Does tend to pull to one side a bit.
Reply #16 on:
September 28, 2012, 10:11:14 PM »
Won't be a problem til you have to Go the other way round the circuit
BTW-UK forum
BTW-Area51
Reply #17 on:
September 29, 2012, 06:41:06 PM »
Picked up the wheels today and will keep a photo diary of how it goes! If it works and they look good, i will post pics, if not, forget I ever mentioned the whole silly idea
Might take a while as work on the trike has to take precedence.
Reply #18 on:
September 29, 2012, 09:16:02 PM »
I visited Mr Newbie this evening & can report his trike looks gee-orgeous in the flesh. Nice.
Reply #19 on:
September 30, 2012, 01:41:09 PM »
banding is illegal in Australia. you can cut 2 rims asymmetrically and weld the bigger bits together.
law is only for 1 weld around the rim
brought on by heaps of failures from dodgy backyard jobs done in the '70's
Reply #20 on:
September 30, 2012, 02:29:32 PM »
Newbie's planning to rivet the wheel centres to a different set of rims. Early Moggy Minors had seperate centres, rivetted to the rims. He's planning Vauxhall or Ford Transit van.
The North
Reply #21 on:
September 30, 2012, 07:31:03 PM »
Not sure but were the centres not riveted then spot welded either side and in between the three rivets
I think if you grind off the paint / rust you will see the spot welds .
Reply #22 on:
September 30, 2012, 07:38:20 PM »
Nope just riveted on. Have taken out one centre (and a chunk of finger), but intend to rivet
and
weld into the new rim
The North
Reply #23 on:
September 30, 2012, 08:00:12 PM »
Surprised at that i would have had money on them being spot welded too. modern cars just spot weld them. i like the idea of the rivets as well, be a sound job.
Reply #24 on:
September 30, 2012, 08:26:12 PM »
Emailed you about the other wheel Dave.
Pages:
