Title: Welding Mask Post by: morrag on October 19, 2018, 07:50:47 PM How good, or bad! are the cheapo auto darkening welding masks, and how important is a battery change facility on a solar powered mask, and also by cheap I mean around £20! cheap,if thats a practical option.....Morrag
Title: Re: Welding Mask Post by: Manky Monkey on October 19, 2018, 08:25:51 PM I've got a solar powered one that cost about 50 quid, which seemed to work well. I haven't used it for a couple of years though & did wonder if the battery would be buggered by now.
Title: Re: Welding Mask Post by: TwistedPatience on October 20, 2018, 06:00:39 AM I bought an Aldi one for £22 seems fine not got arc eye.
Title: Re: Welding Mask Post by: Olds on October 20, 2018, 09:26:12 AM I bought a cheapish one in about 2013 and the reaction time is starting to get a bit slow, so I think the battery may be on the way out. Seems OK if I leave it out in the sun or under a bright light for quite some time before using it.
One day I will see if I can change 'sealed' battery. Title: Re: Welding Mask Post by: the coppersmith on October 20, 2018, 09:40:43 AM When I was fully employed welding, I had the best screen, air fed "speedglas" the thing lasted for years, since calling it a day it has given up. I bought an ebay special, works does the job, but when into Tig welding it is a bit restrictive in light Mig is fine, and Mag I always use an old fixed lens.
Title: Re: Welding Mask Post by: morrag on October 20, 2018, 01:12:22 PM Many thanks guys, as ever, informative...Morrag
Title: Re: Welding Mask Post by: minimutly on October 20, 2018, 07:26:08 PM I'm on my third battery powered helmet - seely one failed outside warranty - no suprise there. A really expensive (£100 odd) one failed and was replaced foc, it's now on its way out again after a year or two - It really pees me off to get arceye flash the first few times I press the tig button.
Get one with a replaceable battery or a cheap one and replace every two years or so. As someone said, leave it in the sun between usage helps. Title: Re: Welding Mask Post by: Dslam on October 20, 2018, 07:40:42 PM I bought a helmet from R Tech where I got my TIG from. It cost about £50 and has a replaceable 'button' battery. The size of a 2p.
You know when the battery is on the way out when the lens delay slows slightly. Not enough for arc eye but noticeable. Title: Re: Welding Mask Post by: morrag on October 20, 2018, 11:21:51 PM If the battery is installed before dispatch, then there must be a way of changing it, surely? let me know what you discover Dave................. ??? ???
Title: Re: Welding Mask Post by: Olds on October 21, 2018, 05:59:23 AM If the battery is installed before dispatch, then there must be a way of changing it, surely? let me know what you discover Dave................. ??? ??? It's a matter of getting into it. Don't think I can pry it apart without damage. It's a sealed unit. The sensitivity potentiometer needs a tap occasionally so really needs cleaning/replacing but the tint control and screen etc. are still good so it might be worth trying one day. but probably easier to just buy a replacement adjustable solar lens. Lots on Fleabay but be wary, sight is precious.Price varies from about £8 for a basic one to £280 for a Speedglas :o but you should be able to find one with changeable batteries etc. for a reasonable price. Title: Re: Welding Mask Post by: minimutly on October 21, 2018, 04:29:55 PM That's exactly the same as the sealy one I had, I did manage to rip it apart but gave up, tbh I don't remember why. Maybe the battery was difficult to find a replacement.
Title: Re: Welding Mask Post by: morrag on October 21, 2018, 09:41:17 PM Quite honestly, I do very little welding these days, and when I do it's rarely of a prolonged nature, so I have sent for an "E" Bay 'special' and see how I go on with that, worst case scenario would be its junk, but at a price I can't complain over, so..... :D :D :D...cheers, Morrag
Title: Re: Welding Mask Post by: poprodder on October 22, 2018, 09:40:06 AM this is mine, cheap from aldi, but great reviews.
(https://storage04.dropshots.com/photos8000/photos/1101204/20180914/b_111640.jpg) Title: Re: Welding Mask Post by: terry t on October 22, 2018, 12:44:28 PM When mine packed up I called into the local welding suppliers and asked for replacement battery or solar powered screen. he said it would be cheaper to buy another helmet for £20. he did say if its not use a lot don't put it back in the box as the solar panel keeps the battery topped up!
Title: Re: Welding Mask Post by: morrag on October 27, 2018, 02:59:35 PM I'm so impressed with my new welding mask, I'm welding things....that dont require welding!!!!!😀😀😀so, what's the,Best way of storing an infrequently used mask of this type, with the need to keep the non removable battery charged, morrag
Title: Re: Welding Mask Post by: Olds on October 27, 2018, 08:19:34 PM As far as I understand, just leave it in a light place. I hang mine in the garage, on the wall, I suppose if you want to keep it clean and grinding grit etc. off it when not in use, a clear plastic bag might be a good idea.
Title: Re: Welding Mask Post by: morrag on October 27, 2018, 10:48:23 PM Seems sensible Dave.....
Title: Re: Welding Mask Post by: minimutly on December 23, 2018, 01:27:15 PM The ultimate throwaway society-
My replacement jackson safety helmet died, batteries flat (again). So I went out and bought a Starparts fully adjustable, replaceable 2032 battery one. It's very good. Maybe I did this arse backwards (the need for welding was urgent), but I had a go at ripping the jackson safety module apart. Eventually the clips (and glue - why?) gave in. Two lithium pcb cells, soldered into the board. I removed one to get as much info off it as I could - they don't seem to be rechargeable, so RS components to he rescue. Two punds, yes two bloody quid later, and they're on the way.... A hundred quid helmet, scrap because of two bitty batteries, I ask you. Merry Christmas all! Title: Re: Welding Mask Post by: Manky Monkey on December 23, 2018, 04:16:18 PM But if you replaced the 2 quid batteries, you wouldn't buy another helmet -that's a bad business plan! :)
Title: Re: Welding Mask Post by: hornet6 on December 23, 2018, 05:34:43 PM I keep my welding helmet in the spare bedroom, so its charging up during the day.
