May 15, 2024, 08:00:10 PM *
Pages: [1] 2 3 ... 14
Author Topic: Paulywombats Honda St1100 Conversion  (Read 43349 times)
« on: June 15, 2017, 06:10:37 PM »
Hi All
Thought I'd start a post about my current project, converting a Honda ST1100 Pan European year 2000, ex police bike with 60,000ish miles.
Going to try and post pics as and when.
Paul
Living on a wing and a weld
« Reply #1 on: June 16, 2017, 09:49:02 PM »
Ooh! A new build to read -we like build threads  Smiley
Should be an interesting one.
« Reply #2 on: June 16, 2017, 09:51:22 PM »
Converting to what ?
« Reply #3 on: June 17, 2017, 05:42:59 AM »
A trike my friend Wink
« Reply #4 on: June 17, 2017, 02:26:27 PM »
As bought in January
« Reply #5 on: June 17, 2017, 02:47:37 PM »
Swingarm removed ready for surgery
« Reply #6 on: June 17, 2017, 03:15:22 PM »
Oh my Gawd.-it's started! It'll end in tears. And bankruptcy. And madness! Run now while you still can. Run like the wind!
« Last Edit: June 18, 2017, 08:01:36 AM by Manky Monkey » Logged
« Reply #7 on: June 17, 2017, 06:56:39 PM »
Oh no Andy, full of wind and mad?
Too late Cheesy
« Reply #8 on: June 28, 2017, 03:54:44 PM »
Hub after machining
« Reply #9 on: June 28, 2017, 03:57:01 PM »
Tother end
« Reply #10 on: June 30, 2017, 09:58:31 AM »
I don't see why youd want to machine doen the outside diameter? Nice to see the 12mm offset studs though, very sensible.
« Reply #11 on: June 30, 2017, 12:14:40 PM »
It was machined to grip in the lathe chuck to machine the other side.
stumpy
« Reply #12 on: July 06, 2017, 08:32:13 AM »
The oil seal may leak now as the inner side of hub needs to be snug in seal !
« Reply #13 on: July 10, 2017, 07:29:59 PM »
The hub doesn't sit in the oil seal. It's the shaft that runs in the oil seal. The hub is on the outside of the bearing and only connects with the taper on the shaft.
If you look at a hub, the casting is rough cast, this is what has been turned.
« Reply #14 on: July 10, 2017, 08:34:36 PM »
Any more progress yet Paul?  Smiley
