May 17, 2024, 02:23:19 AM *
Author Topic: Kwaka 750 LTD starter motor  (Read 2203 times)
klogan45
« on: January 14, 2009, 07:09:11 PM »
Can anyone help out please.... my mat has a 750 LTD, which has developed a starter problem.
When he presses the button, there's a horrible graunching noise. It will eventually start....at the moment.
Can anyone tell me what this may be?
Another mate reckons that its either the starter or the starter ring gear. I had a Virago with the same symptoms but that turned out to be the starter clutch ( spragg clutch ?) I found this to be quite an easy and fairly cheap fix.
Does the LTD 750 have a spragg clutch? Or is the starter similar to that on a car? Any other ideas would be gratefully recieved. (except those that say 'get rid of the bloody thing, burn it etc Shocked Shocked Grin Grin Grin Grin)
Thanks all
Regards
K
« Last Edit: January 14, 2009, 07:32:36 PM by klogan45 » Logged
« Reply #1 on: January 14, 2009, 08:28:44 PM »
Cant remember if this is the 750 or1000 setup but either way it`ll be somethin like
« Last Edit: January 14, 2009, 08:32:10 PM by tbone » Logged
toad
« Reply #2 on: January 14, 2009, 08:48:44 PM »
its a fairly common fault its the springs and rollers in the assembly that get worn and weak sometimes just stretching the springs to make them longer provides a fairly good temp repair.  Wink
klogan45
« Reply #3 on: January 14, 2009, 09:59:51 PM »
Thanks to you both for your replies. We'll probably have a look and try and sort it over the week end
I'll keep you posted
Regards
K
