« on: September 08, 2008, 06:39:27 PM » |
wanna do a DPM paint job on a trike but try as i might i just cant get it looking right, anyone got any experiance with this?
« Reply #1 on: September 08, 2008, 08:40:08 PM » |
O.K, I'll ask -what's DPM?
« Reply #2 on: September 08, 2008, 08:51:07 PM » |
Disruptive Pattern Material. The proper name for camouflage. Uniforms in DPM has been in use since 1969. The first uniforms were called "Pattern 1960" as they were based on the plain green 1960 uniform. Pattern 1968 began being introduced in the start of the seventies. It was later superseded by the Pattern 1984. This pattern proved unsatisfactory and was then replaced by the Pattern 94.
« Last Edit: September 08, 2008, 08:58:40 PM by tbone »
monty
I hate a government that knows whats best for me
« Reply #3 on: September 09, 2008, 08:03:15 PM » |
Option 1 get an ex squady and give him a paint brush Option 2 give the brush to the kids next door
« Reply #4 on: September 18, 2008, 10:47:06 PM » |
Its taken me a while but i finally managed to draw a repeating DPM pattern (below). The square can be put side to side and top to bottom to create the desired size. I`m not using the tradational olive green in the final spray cos i think its too dark, gone for a leaf green instead, but the brown, sand and black will be used.
« Reply #5 on: September 18, 2008, 10:51:56 PM » |
Kool Tbone not an easy task by the looks of it.
kustom
« Reply #6 on: September 18, 2008, 11:20:55 PM » |
if you lived in america you could have it dipped i seen done on occ once but you can do it with an airbrush
« Last Edit: September 19, 2008, 02:01:59 AM by kustom »
« Reply #7 on: September 19, 2008, 01:37:50 AM » |
hmm typical i used to have a full set of the print used in camo, as i used to set up the material before coverage,"i worked under dierect contract to the ministry" death and destruction was our major line
« Reply #8 on: September 19, 2008, 09:49:07 AM » |
I saw that episode, bloody neat idea
« Reply #9 on: September 19, 2008, 06:27:42 PM » |
how does this `dipped` work then? Gareth, you should know never to get rid of owt
kustom
« Reply #10 on: September 19, 2008, 06:48:40 PM » |
details here m8 visit the site below and click the link at the top of the page and you can see them doing it http://www.tarjac.com/
« Last Edit: September 19, 2008, 06:50:40 PM by kustom »
« Reply #11 on: September 19, 2008, 07:09:27 PM » |
very impressive. If i understand correctly, the cemical thats sprayed onto the sheet must soften the ink pattern which then sticks to whatever is being rolled. I`m puzzled as to why the ink doesnt dissipitate in the water though. can only assume that what is actually applied to the dipped part is a very thin film, a very posh way of using self adhisive stickers lol
« Reply #13 on: November 27, 2008, 07:34:51 PM » |
I did actually finish this last month but lost the pics, sorry. Have got a couple though and will take another of the completed tank.
« Reply #14 on: November 27, 2008, 07:37:00 PM » |
top
