May 18, 2024, 07:43:47 PM *
Pages: 1 ... 662 663 [664] 665 666 ... 791
Author Topic: Manky's Pop.  (Read 1565705 times)
« Reply #9945 on: October 22, 2017, 11:17:02 AM »
I have no idea what happened there, half my post disappeared into the wild web  Cheesy
What you could do with is a hydraulic hose shop, we have several in Plymouth that I frequent. Pressure lines and hoses for machines etc. I have supplied a link for you to browse. The bleed holes are normally the same as a brake male fitting, taper wise, thread wise metric or imperial? But they are standard threads for brake lines.
link: https://www.ebay.co.uk/i/391809414757?chn=ps&dispItem=1&adgroupid=42825902799&rlsatarget=pla-327950624104&abcId=1129006&adtype=pla&merchantid=7340654&poi=&googleloc=1007173&device=c&campaignid=861899693&crdt=0
« Reply #9946 on: October 22, 2017, 11:21:32 AM »
One of these on each side of the bulkhead?
http://www.ebay.co.uk/itm/282631082386
How would I seal a brake pipe into a bleed nipple port? Short male fitting & a copper washer? I've got a reel of copper pipe, a flaring tool & a brake pipe bender, but never made up copper brake pipes on my own.
« Reply #9947 on: October 22, 2017, 11:27:54 AM »
Is it a long way? maybe a flex to the bulkhead? twice as you say. I'll dig some info out from my Hydraulic catalogue.
You should be able to make a brake pipe end, double flare and with the right size nut or screw tighten it into the brake booster no problem. Or as you say a male thread and washer tightened in.
« Reply #9948 on: October 22, 2017, 11:33:31 AM »
these are the last people I used, coz they were cheapish
https://www.ebay.co.uk/i/182045709016?chn=ps&dispItem=1&adgroupid=42825902799&rlsatarget=pla-326572631493&abcId=1129006&adtype=pla&merchantid=7266054&poi=&googleloc=1007173&device=c&campaignid=861899693&crdt=0
« Reply #9949 on: October 22, 2017, 11:57:53 AM »
Just google it Andy not sure what flaring tool you got but here are some videos on how to make up brake lines
https://www.bing.com/videos/search?q=how+to+flare+brake+lines&&FORM=VDVVXX
« Reply #9950 on: October 22, 2017, 12:05:04 PM »
About 12" from servo bleed port to a suitable point on the bulkhead. One either side.
I've been looking at this all the time I've been cleaning up & Dynamatting the bulkhead, but the servo mounts to the tubular frame that supports the steering wheel etc. That's at the welders at the moment. I'm also waiting for someone to machine up the solid slugs to mount the frame to the chassis. So was going to wait till it was all re-fitted so I can route the pipework around everything. I could drill the bulkhead & bolt in the fittings though.
« Reply #9951 on: October 22, 2017, 12:08:33 PM »
Google is a wonderful thing Smiley
This type:
http://www.yarmo.co.uk/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/p/f/9008b31e70de0c63c9f3effc464475e1/yarmo-sealey-on-vehicle-micro-brake-pipe-flaring-tool-pft12-pft12-30.jpg
« Reply #9952 on: October 22, 2017, 12:13:29 PM »
I have one of those nice and easy to use. just make sure use put a small amount of grease on the flaring tip.
« Reply #9953 on: October 22, 2017, 12:49:27 PM »
Right-o.
« Reply #9954 on: October 22, 2017, 01:15:41 PM »
Do you have a old flexi brake hose? you could try it in the thread. Brake hoses are easy to make up and could solve many little problems later.
« Reply #9955 on: October 22, 2017, 02:55:44 PM »
When I rode motorcycles regularly I had a big box of spare Goodrich hose & various fittings. Long gone now.
« Reply #9956 on: October 22, 2017, 03:43:01 PM »
do you have a brake pipe fitting that will screw in where the bleed nipple is? that will give you the thread.
« Reply #9957 on: October 22, 2017, 05:52:26 PM »
My day off tomorrow. I've got to go & buy some stainless Imperial bolts, (my local bolt shop doesn't stock them), so will bung the servo in the boot of the car & nip over to Merlin Motorsport in Wiltshire while I'm out. I can pick up everything I need there.
« Reply #9958 on: October 22, 2017, 06:31:37 PM »
From memory Andy I think they where 3/8-24 unf fitting. I'm sure Kev will know.
« Reply #9959 on: October 22, 2017, 07:54:56 PM »
You've got a far better memory than me Terry!
As I said, I've been thinking about this while working on the bulkhead, so, as it's been mentioned, I might as well get it sorted.
