May 15, 2024, 07:48:33 AM *
Pages: 1 ... 68 69 [70] 71 72 ... 89
Author Topic: New Olds (boat tail speedster)  (Read 404646 times)
Mendalot
« Reply #1035 on: July 23, 2016, 09:58:33 PM »
I love it when a plan comes together Cheesy  Must admit that I was also under the misconception about the adjusting principles Shocked  Tis a true saying that one never stops learning.
« Reply #1036 on: July 24, 2016, 07:56:43 AM »
Not as glad as I am that it works. Second hand parts cost enough, so to have the idea fail would have made a dent in the budget that I really can't afford. Now that I know the idea is sound I don't mind paying out for the new parts required. Will be using the second hand back plates as they are about £120 +VAT each which is a lot to pay out if you are going to cut, drill and weld them. May also use the old drums, as they are well within their wear limits and have cleaned up OK.
« Last Edit: July 24, 2016, 08:40:15 AM by Olds » Logged
« Reply #1037 on: July 24, 2016, 09:08:14 AM »
They do look original and made for the job,well done sir Cool
« Reply #1038 on: July 24, 2016, 02:42:55 PM »
Nicely done Dave, as per, and I agree, they look the part, as well, so, a "result".... Grin Morrag
« Reply #1039 on: July 25, 2016, 07:17:01 AM »
Cheers guys. Yep, was hoping they wouldn't look out of place, as they are a lot bigger.
Great thing about them being Ford based is that the internal parts are so cheap and easy to get hold of.  Cheesy There is also a choice of wheel cylinder bore sizes to chose from.
Modified back plate. There is a little more work in this than it looks. The extra mounting holes are obvious, but there is also an extra shoe wear inspection slot added, the hand brake gaiter retaining plate has been ground off and the hand brake lever slot filled and welded up.
« Reply #1040 on: July 25, 2016, 02:18:32 PM »
Looks great Dave and a good addition to BIVA knowledge Smiley
« Reply #1041 on: July 25, 2016, 03:24:31 PM »
great work there dave.
« Reply #1042 on: July 25, 2016, 04:03:03 PM »
Just what I said to Dave yesterday Kev -nice to think you've created something that'll make your own vehicle unique, but info that could prove very useful to a future BIVA builder.
« Reply #1043 on: July 25, 2016, 04:54:43 PM »
D'oh! Should have kept it a secret.  Cheesy
« Reply #1044 on: July 25, 2016, 06:56:58 PM »
You can't keep HOLES a secret ? Wink
« Reply #1045 on: July 27, 2016, 10:01:15 PM »
 Cheesy
The other backplate is now done and so is the brake drum. Still need to machine the other hub and I'm waiting for postie to deliver new cylinders, shoes and springs etc. When the new shoes are fitted, I will be able to finalise the minimum distance between the arms on the adjusters.
« Reply #1046 on: July 29, 2016, 06:29:44 AM »
D'oh!
Just noticed that the original wheel cylinders are 7/8" (22.2mm) and I thought they were 3/4" (19mm). The ones I have bought are 13/16" (20.6mm)  Roll Eyes
The 36 per cent increase in shoe width and more efficient design might outweigh the reduced piston force but after much searching I have found that the Escort Mk3 RS Turbo used 22.2mm bore cylinders in the same piston end design, so will get a pair of those.
« Last Edit: July 29, 2016, 07:44:37 AM by Olds » Logged
« Reply #1047 on: July 29, 2016, 04:41:55 PM »
Brake shoes arrived !  Grin
However there is a problem. Angry
Anyone see what it is?
toad
« Reply #1048 on: July 29, 2016, 05:51:47 PM »
Oversize lining on one shoe  Wink
« Reply #1049 on: July 29, 2016, 06:35:24 PM »
That's all I can see -the lining on the one on the far right extends further round the shoe than the others -& they're all the same. Should they be handed?
I can't find Wallie though.
