Title: clicking noise on xv535 Post by: klogan45 on August 22, 2011, 07:49:35 PM Hi guys, yet another problem i'm afraid :'(
Had a new tyre on the Virago xv535 a couple of months back. Since I got it back there's been an annoying clicking noise. I checked the obvious, nothing stuck in tyre, nothing touching as the wheel turns. It only seems to do it when I'm rolling with the clutch pulled in I thought perhaps that I couldn't hear it cos of the engine noise. Today I had a eureka moment. I switched off the engine, put the bike in gear pulled the clutch lever in and rolled the bike forward the Bl@@^$£*y noise was there. It's not from the wheel after all. It doesn't to do it if the clutch lever is not pulled in. To my mind this points to the clutch but I have never come across this before so I really have no idea. Any suggestions before I start to pull things apart or even take it to the bike shop and spend, probably, loads of the hard earned :( :( Any suggestions/solutions will be gratefully received Thanks Regards K Title: Re: clicking noise on xv535 Post by: Cabman77 on August 22, 2011, 08:02:49 PM a quick whip off of the clutch housing might show the problem up for what it is ;D ;D ;D ;D
Title: Re: clicking noise on xv535 Post by: chopper charlie on August 22, 2011, 08:10:46 PM Shagged selector forks'll click on rotation of the layshaft
Title: Re: clicking noise on xv535 Post by: klogan45 on August 22, 2011, 09:20:09 PM Thanks cabman, do you think you know what the problem is?
I've also now found that it does not click when the clutch is engaged, had a nice quiet little slow ride earlier on without my helmetn, around the car park outside of our garages (private land) only does it when the clutch lever is pulled in, makes me think that the clutch basket may be loose or something has 'come adrift' maybe. . Thanks Chopper Charlie but it selects gear with no problem that I can feel so I'm hoping that the selector forks are ok, be very expensive if they are knacked :'( :'( Regards K Title: Re: clicking noise on xv535 Post by: BikerGran on August 22, 2011, 09:48:19 PM Has it got enough oil in?
Title: Re: clicking noise on xv535 Post by: klogan45 on August 22, 2011, 09:51:33 PM Good thinking BG, I'm sure it has but I'm going to double check tomorrow. Strange thing is it only does it when I pull the clutch in and in gear and rolling in traffic etc. There is no clicking when the clutch is engaged. Got me stumped, then again that's not difficult to do :-[
Regards K Title: Re: clicking noise on xv535 Post by: Cabman77 on August 23, 2011, 08:07:54 AM makes me think that the clutch basket may be loose or something has 'come adrift' maybe. . Regards K I agree it seems like something has worked loosed in there. Bite the bullet and stop guessing and start wrenching to see the problem. ;D ;D ;D ;D Title: Re: clicking noise on xv535 Post by: klogan45 on August 23, 2011, 11:19:36 AM You're right cabman, it's time to stop buggering about and have a look ;D. I'm going down to the garage shortly and get the spanners out ;D ;D
Regards K Title: Re: clicking noise on xv535 Post by: hunter on August 23, 2011, 12:21:24 PM That spanners gets everywhere ;D
Title: Re: clicking noise on xv535 Post by: Cabman77 on August 23, 2011, 02:21:41 PM That spanners gets everywhere ;D Well he does need to get out more ;D ;D ;D ;D Title: Re: clicking noise on xv535 Post by: klogan45 on August 23, 2011, 05:45:53 PM Well.....the tale ends here he said hopefully ;D
I got to thinking about Bobbi's comment... Quote Has it got enough oil in? I checked the old oil level and it seemed to be where it should be in the oil window thingy. (To do this I got Mrs.K to sit astride the beast outside the garage (The neighbours were quite shocked) then I got her to sit on the bike and hold it level while I checked the oil level. I decided before I went I then took the bike out for a run. Guess what....... No clicking noise. RESULT...I hope. I'll let you know after I've put a few more miles on the clock. I don't know why it's ok now, it was maybe just 'attention seeking'. Thanks one and all for your comments/suggestions. Regards K Title: Re: clicking noise on xv535 Post by: Manky Monkey on August 23, 2011, 11:20:39 PM Amazing how easy it is to overlook the basics isn't it!
At least it's a cheap fix K. ;D Title: Re: clicking noise on xv535 Post by: klogan45 on August 24, 2011, 11:36:04 AM Quote Amazing how easy it is to overlook the basics isn't it! I'd have never thought about the oil particularly as it had a (supposedly) full service before I got it. :-[ I've also never come across this type of thing before. So...thanks again one and all. Title: Re: clicking noise on xv535 Post by: Cabman77 on August 24, 2011, 08:35:31 PM did you get a lot of filings in the old oil??
Title: Re: clicking noise on xv535 Post by: klogan45 on August 24, 2011, 10:08:33 PM Quote did you get a lot of filings in the old oil?? Funnily enough no I didn't which surprised me. That flippin' clicking must have been from somewhere. had a good ride out today, put a few miles on the clock and it was running really well, really pleased. Title: Re: clicking noise on xv535 Post by: BikerGran on August 28, 2011, 09:04:49 PM I find that my GT tells me when it wants an oil change as I start finding a lot of false neutrals - I guess this is just your bikes way of letting you know!
Title: Re: clicking noise on xv535 Post by: klogan45 on September 04, 2011, 06:43:44 PM Good call Bobbi, I would never have thought of something so simple.
Thank you Title: Re: clicking noise on xv535 Post by: BikerGran on September 05, 2011, 12:04:57 AM Other folks are very good at all the technical stuff but I find it's always best to start simple!
Title: Re: clicking noise on xv535 Post by: klogan45 on September 07, 2011, 10:06:27 PM Quote Other folks are very good at all the technical stuff but I find it's always best to start simple! Sometimes simple is best ;D Title: Re: clicking noise on xv535 Post by: Hagar on September 07, 2011, 10:55:35 PM Sometimes simple is best ;D That must mean I work with all the best people .............. ;D .. Hagar .. ;D Title: Re: clicking noise on xv535 Post by: klogan45 on September 12, 2011, 06:56:59 PM Quote That must mean I work with all the best people .............. Grin You and me both................... ain't we the lucky ones ;D Title: Re: clicking noise on xv535 Post by: trikerpete on September 29, 2011, 03:26:58 PM did you get a lot of filings in the old oil?? No, but a medium sized "click" fell out of the drain hole ::) :D Title: Re: clicking noise on xv535 Post by: spanners on September 29, 2011, 10:01:19 PM was it ,,mettallic,,,,
Title: Re: clicking noise on xv535 Post by: trev on September 30, 2011, 11:07:47 AM what... a rock band.? ::)
