May 19, 2024, 06:36:25 AM *
Pages: 1 ... 268 269 [270] 271 272 ... 791
Author Topic: Manky's Pop.  (Read 1565902 times)
« Reply #4035 on: October 29, 2011, 11:02:19 PM »
it should be this one Mike.....65amp with stud terminals.
Tim its the same hand as this one. it has spade terminals on the old one
http://www.ebay.co.uk/itm/Alternator-Land-Rover-V8-Classic-MG-TVR-SD1-Kit-Car-/170716803054?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bf83afee
« Reply #4036 on: October 29, 2011, 11:08:58 PM »
that aint cheap  Shocked
i,ll also see if ,smokey, has one tommozz
« Reply #4037 on: October 29, 2011, 11:19:15 PM »
heres a photo of it on the car
« Reply #4038 on: October 29, 2011, 11:32:50 PM »
thats an old 15 or 17 acr  only just upto the job for a v8  got one sat on a rebuilt ford engine under the carport belongs in one of the duttons..
you can get them with a bigger output but they have a differant rear cover.
« Reply #4039 on: October 30, 2011, 08:12:30 AM »
Standard ACR unit, good call Mike  Wink
Will only be a maximum of 45amps as it has spade terminals on, as Mike points out, that would be pushing it for a V8, but your not running tons of un needed electrics.
LRA101 is the lucas part number for a 36amp unit, should be around £45.
What size is the battery?
dobber
« Reply #4040 on: October 30, 2011, 10:48:57 AM »
yep maybe more there,s also around 60 starter motors going in the skip Shocked
and i havnt got in through the door of the small workshop yet and there,s even a biggish lathe in there somewhere
saw that workshop mike, a major part of  spanners wonderland.
        can i have it in 20 Min's?
« Reply #4041 on: October 30, 2011, 10:53:43 AM »
big  Grin
i think its this one Tim. as its the one halfords list for a sdi 3500 rover HB072
■Startup Power: 510 Amps
■Type: Lead Acid
■AH Value: 68
■Bench Charge: 6.8 Amps
■Reserve capacity: 125
« Reply #4042 on: October 30, 2011, 12:07:49 PM »
Where did you find that photo Terry?! I was scouring the thread last night for a pic, (using Taz's old laptop & most of my photos are stored on my old PC), & couldn't find one. That was when we were wondering if we had to keep the old ballast resistor or not, (the flat aluminium unit hooked up to the coil).
Not sure of the battery's output, but it's from Halfords & was the one they listed for V8 Landrover Discoverys, so I figured it'd be up to the job.
I bought the Rover engine & gearbox from a local guy who said it'd come from a Standard 8 drag car. No paperwork with it, just the motor & box sat on a wooden trolley. So there's no guarantee anything fitted on it's original.
« Reply #4043 on: October 30, 2011, 12:30:48 PM »
on this thread. it was back in sept 13 2010. on page 152.
« Reply #4044 on: October 30, 2011, 12:32:03 PM »
Yep, that 072 battery is fine, I`d like to see a 65 amp alternator coupled up to it but as i said, your not needlessly using power so a 45amp will be fine.
« Reply #4045 on: October 30, 2011, 12:38:50 PM »
yes as you say Tim. it has only got just the basics. lights indicator hazards fans reversing/fog lights and wipers.
no fag lighter or radio  Grin
« Reply #4046 on: October 30, 2011, 01:43:01 PM »
Not even an interior light. I don't smoke & who needs a radio with a dirty great V8 under the hood!
« Reply #4047 on: October 30, 2011, 06:21:07 PM »
This is what it should sound like. This is from a slightly earlier Rover. A P6. Same engine though & same Borg Warner auto gearbox. This one has the alternator in it's original position at top right of the engine. Mine's relocated to bottom left. It also has the original twin SU carbs, (I've replaced mine with a single Holley).
YouTube Rover start up
NeilG
« Reply #4048 on: October 30, 2011, 07:31:44 PM »
Haven't got any alternators left,used the last one I had on the Chevy a while back.
I've always just used the Lucas 17 acr,ran them on my rover and got one on the Chevy,plenty powerful enough for what you need.
« Reply #4049 on: October 30, 2011, 07:41:59 PM »
I have just seen the video that Andy posted. and is see that the engine turns over in a clockwise direction when standing in front of it.
if thats right then the are the fins one the alternator in the photo right.
