May 14, 2024, 03:39:42 AM
General Tech
fuel guage
Topic: fuel guage (Read 3141 times)
twolanes
PRO ET/571
fuel guage
March 21, 2008, 12:18:13 PM »
i have a fuel cell that i want to fit into a dodge, but the guage sender unit is for a GMC and the ohms reading is the wrong way round (0 when empty, 90 when full) mopar should be 0 when full, is there any way to convert convert it, IE fit a resistor or
Re: fuel guage
April 15, 2008, 11:59:28 AM »
Use the gauge from a GMC is probably the easiest solution.
Re: fuel guage
April 15, 2008, 07:14:59 PM »
Reverse the connections. if it is single wire connection One end is connected to the body/earth. the other to the gauge/positve. If you can connect them so the wire from the coil on the sender that goes to positive is grounded and the wire that connects to the body/earth connect to the live this will reverse the senders readings.
hope that helps
http://www.choppit.co.uk
Re: fuel guage
April 15, 2008, 09:45:13 PM »
Sounds simple when you know how - it's the knowing that's the clever bit!!
Re: fuel guage
April 16, 2008, 06:36:32 PM »
Thanks Bobbi. ows the build going?
twolanes
PRO ET/571
Re: fuel guage
April 17, 2008, 02:54:11 PM »
Quote from: ByzMax on April 15, 2008, 07:14:59 PM
hope that helps
Will give it a try.Thanks.Dave.
Re: fuel guage
Reply #6 on:
April 17, 2008, 09:45:39 PM »
Quote from: ByzMax on April 16, 2008, 06:36:32 PM
Slowly!
