May 21, 2024, 10:33:49 PM *
Pages: 1 ... 12 13 [14] 15 16 ... 89
Author Topic: New Olds (boat tail speedster)  (Read 406018 times)
« Reply #195 on: October 25, 2014, 07:39:30 PM »
VERY, VERY, impressive. I wish I could think up ideas like this, or similar ones, or any ideas full stop ! Grin
« Reply #196 on: October 28, 2014, 12:38:08 PM »
Hmmm. Can't see Chewie's picture so I will assume those nice comments are about mine  Cheesy
Bits temporarily pop riveted and screwed together. Want to do some small modifications/adjustments before final assembly, but this shows what I intend. The general idea is the whole rear end, can easily be hinged up or removed completely.
« Last Edit: October 28, 2014, 12:42:42 PM by Olds » Logged
« Reply #197 on: October 30, 2014, 09:25:32 AM »
love it sir.... wonderful job......
« Reply #198 on: October 31, 2014, 02:12:39 PM »
Thanks Shaun.
The search for parts, at reasonable prices continues and Christmas has come early. A pair of new Brooklands aero screens bought for less than damaged second hand ones .  Grin
« Reply #199 on: October 31, 2014, 02:22:27 PM »
I'd been looking for a cheap single one for ages, ended up making my own version:(
« Reply #200 on: October 31, 2014, 07:25:30 PM »
So have I!
« Reply #201 on: October 31, 2014, 08:11:49 PM »
I got fed up of bidding on ones that had chipped glass or fitting missing only for then to sell for about £70 + £10 p&p for one.
Found these new, for £130 the pair, including delivery. Not exactly cheap but they should be perfect for the speedster. Unless I go for a cut down Duvall screen that is.  Wink
« Reply #202 on: October 31, 2014, 08:17:28 PM »
Yeah, I think you should go for a Duval screen - then sell one screen each to Kev & me! (Looking for a single one for the T bucket project).
« Reply #203 on: October 31, 2014, 08:54:20 PM »
Now of all members/visitors to this site, you Olds I would have put money on making those yourself!.I am surprised, really Shocked Shocked Shocked Shocked Morrag
« Reply #204 on: October 31, 2014, 10:43:52 PM »
I did actually consider that option (but not for long Cheesy ) The cost of a Defender windscreen then getting it cut and the edges ground, let alone making the frames, made me decide it wasn't worth the effort.
 A previous attempt at cutting laminated glass didn't go too well  Embarrassed
« Reply #205 on: October 31, 2014, 11:06:59 PM »
Get your drift, but what about an industrial grade perspex, the sort of thing you would make guarding from? as an alternative to Laminated glass. Morrag
« Reply #206 on: November 01, 2014, 04:52:49 AM »
Yep, something like 6mm Lexan/Makrolon would be fine.
Looking to make a pair of screen mounting aprons as fitted to MG T types.
« Last Edit: November 01, 2014, 04:54:24 AM by Olds » Logged
« Reply #207 on: November 01, 2014, 02:59:36 PM »
I used 6mm Lexan on mine in the end as well.
« Reply #208 on: November 02, 2014, 09:25:34 AM »
Did you make any sort of frame Kev, or just use brackets ?
Used to use Makrolon over roll cages. It's incredibly tough and often wondered if it could be used as an alternative body skin material but then it's also expensive.
« Reply #209 on: November 02, 2014, 03:45:18 PM »
Used the lean itself with through U clamps but then cloaked it in ali strip to look like it was actually sitting in a frame.
PM me your e mail and I'll send a piccie direct as I struggle with loading photos on here.
