May 14, 2024, 03:01:38 PM *
Pages: 1 ... 20 21 [22] 23
Author Topic: Morning (Reliant trike build)  (Read 72555 times)
« Reply #315 on: May 06, 2007, 10:24:13 PM »
Very, very pleased for you TT  Grin Congratulations.
In the words of the great Billy Connolly- one less of them, one more of us.
And I know that stupid grin feeling. Abolutely nothing beats the buzz of blatting up the road on something you've sweated & grafted on & created from nothing yourself.
I've just got home form following the three triketeers back from the Shepton Mallet show. I was sat in a big hire van with my own & SaddleBags' trike frames loaded in the back, watching Flap & Si & Ska Man weaving through the traffic on the A303 aboard 3 Reliant trikes at a steady 75 or so.
Can't wait to get out there with 'em.
Terrortubby
« Reply #316 on: May 09, 2007, 08:14:18 AM »
I'm still having bother with this engine, Mick seems to think it has a dwell angle, i'm sort of sure it doesn't. Any ideas?
 It's a 1975 engine and I know it didn't have an SU fitted because I took the old carb off this engine and fitted an SU from a 850 engine.
I need a disk or heynes with all the settings for a 1975 engine.
Anyone know where I could get one?
Won't be making the NABD rally at this rate. Angry
Chaos, Panic. Disorder.my work here is done!
http://grumpygaz.blogspot.co.uk/
« Reply #317 on: May 09, 2007, 11:38:23 AM »
Hiya,
I've got the entire Haynes manual, covering '73 to '83, saved as one huge document. I've sent it to someone before buy they couldn't access it -was that you TT? You'll need Adobe Reader to view it. If you want a copy, let me know & I'll burn it onto a disc, or I can look up the relevant bits for you.
The 750s used a downdraft Zenith carb. When they switched to Sus, they just adapted the existing carb manifold mould. On later models you can see where the Zenith mounting studs used to go. Fitting an early manifold on a later engine's an easy way to turn your carb through 90 degrees to clear bike style petrol tanks by the way.
« Last Edit: May 09, 2007, 11:58:01 AM by Manky Monkey » Logged
Terrortubby
« Reply #318 on: May 09, 2007, 12:01:31 PM »
Hi Andy,
No it wasn't me mate, I have adobe too so should be able to open it.
I could do with the plug gaps, point gap and dwell angle for a 75 mill. leaned it off a tad too and it seems to have helped a bit but it still seems rich and a bit smokey.
It'll only do 80mph flat out and I'm sure it should do a bit more.
cheers mate
Gary
« Reply #319 on: May 09, 2007, 12:31:19 PM »
Our all accelerate really well up to 70 - 75, then level off, but will slowly wind their way up to 85 -90 if you push 'em hard. They're not super quick by modern standards, but perfectly capable of holding their own in traffic. The size of you rear wheels & tyres will greatly affect your gearing & top speed.
I'll bung a copy of the manual in the post to you, but the plug gap should be 25 thou, the points 15 thou & the dwell angle 60 degress +/- 3 degrees on type 23D4 distributors & 51 degress +/- 5 degrees on types 43D4 & 45D4.
« Reply #320 on: May 09, 2007, 12:52:41 PM »
Can't find your address in my extensive filing system. Must've lost the relevant scrap of paper.
Can you PM it to me please matey.
« Last Edit: May 09, 2007, 01:04:03 PM by Manky Monkey » Logged
Firery Fred
« Reply #321 on: May 10, 2007, 12:10:55 PM »
Yo MM, where can I source an early manifold?,can you get them new or do I have to search the scrap yards? The guv'nor's trike has a dummy mustang tank that someone has butchered because of this problem. forever in your debt,Fred
« Reply #322 on: May 10, 2007, 06:28:53 PM »
The later manifolds will work just as well. Take a look at the carb mounting flange on the manifold. It's diamond shaped with two mounting studs. The other two corners of the diamond are where the studs would've been on the earlier models. They just re-worked the old mould. So all you need to do is drill & tap two new holes to turn the carb through 90 degrees.
The earlier Zenith carb used the same size studs as the SU, spaced the same distance apart. My own trike has the carb turned round to face forward, which gives more tank clearance & makes routing the throttle cable tidier.
Terrortubby
« Reply #323 on: May 10, 2007, 06:41:43 PM »
Micks dad had a fiddle and it seems to be running a bit better, Hopefully it will be running for the rally  Grin Wink
I could still use the disc tho andy, cheers mate.
Regards
Gary
« Reply #324 on: May 10, 2007, 06:43:45 PM »
Already in the post Sir.
Terrortubby
« Reply #325 on: May 10, 2007, 06:45:54 PM »
Thanks, have plus 1 on the karma thingy Grin Wink
Terrortubby
« Reply #326 on: May 11, 2007, 06:03:03 PM »
The disc arrived Andy, thanks very much.
Off to the rally tomorrow, taking my camera Wink
« Reply #327 on: May 11, 2007, 07:25:21 PM »
Good man. Have fun.  Wink
Terrortubby
« Reply #328 on: May 13, 2007, 09:40:00 AM »
Went to the rally, no prizes tho.
Lots of people liked it for what it is, a car engined trike built in a shed.
It's fun to ride and even tho it's not very quick it sort of lures you into just tooling along quietly and enjoying the scenery.
I'm going to pull the 850 engine out of the car we have and do it up.
That should give us a bit more ooomph than the 750 lump, Spanners recons fitting a small cherry bomb box may help it breath better than the straight through job with the Vee Dub silencer we have on it.
I'm after a big V twin Jap cruiser for my next project ( scandalous I know!) but I want a bike trike to compliment this one.
Off for a play Wink
« Reply #329 on: May 14, 2007, 10:53:15 PM »
Looked for you at the rally TT, couldn't see you anywhere!
