« Reply #1230 on: May 01, 2009, 08:52:06 PM » |
but not at the same time!
« Reply #1231 on: May 01, 2009, 09:42:07 PM » |
Anything's possible!
« Reply #1232 on: May 01, 2009, 10:43:20 PM » |
It's destined to be a ...snug, fit in the cab I think.
« Reply #1233 on: May 02, 2009, 07:58:27 PM » |
« Reply #1234 on: May 02, 2009, 08:28:11 PM » |
See you in the dirt at next year's Hotrod Hayride then Shaun. Welcome back from your hols by the way.
« Reply #1235 on: May 04, 2009, 08:08:51 AM » |
still aiming for this year mate but it will be in primer with just enough finishing touches to get her legal
« Reply #1236 on: May 18, 2009, 06:21:12 PM » |
andy you runnin rover v8 in the pop? i,m riddin out some stuff overthe next few weeks v8 bits are lying about inlet manifold/carbs,,electroni dizzy,s earl coupe steering boxe,s etc,etc give us a wanted list and i,ll look
also a j reg l/r disco 200tdi for breaking good engine with nearly new g/box
« Reply #1237 on: May 18, 2009, 07:09:48 PM » |
Hiya, yup, Rover 3 1/2. Bought it as a running engine so hoping to at least get it built & registered before having to rebuild it. Got an auto box cos there just isn't enough room in the footwell for a clutch pedal! I'm using a modified Pop steering box, but others here might be interested if you've got spare Rover ones. Called at the workshop on my way home today to do some measuring up of various parts. Ended up unbolting the twin SU carb manifold & bolting on the replacement -a Holley 4 barrel on a manifold that came from a Buick, though I'm not sure whether it's a gennie Buick job or aftermarket. Fitted fine but looks like I need an angled base plate to level the carb up -found a guy who can make them when I was at the NSRA swapmeet a couple of months ago.
« Reply #1238 on: May 18, 2009, 07:12:12 PM » |
Not sure what's been going on in the inlets, but a couple of them were bunged up with a bright pink, soapy substance. Doesn't seem to have done any damage, but will need cleaning out.
« Reply #1239 on: May 18, 2009, 07:18:51 PM » |
I was concerned the new carb would sit much higher than the SUs, which would mean cutting a hole in the bonnet panels. Fortunately it actually sits lower, so even once it's levelled up, we can keep everything inside the lines of the bodywork.
« Reply #1240 on: May 18, 2009, 07:20:59 PM » |
that pinky stuff is in the water ports it looks like a reaction with the type of antifreeze used iv,e seen it before on rover alumium and other makes when you fit the manifold for good change the valley gasket and beshure to renew the rubbers at each end a known source of oil leaks the first time you try to start her up leave the breather traps off or enshure the crankcase can breath freely then if you get a miss/backfire it wont split the valley gasket
« Reply #1241 on: May 18, 2009, 07:23:05 PM » |
That's useful info Mike. Thanks.
Mr_G
« Reply #1242 on: May 18, 2009, 09:52:59 PM » |
S'comin together nicely sir.
« Reply #1243 on: May 18, 2009, 10:35:12 PM » |
if you ever do split a valley gasket through a backfire or simalar DONTput youre finger/s under the manifold they split/tear that sharp it will take finger ends off
« Reply #1244 on: May 21, 2009, 05:14:16 PM » |
Ordered a new thermostat, radiator cap & the end rubbers from "Real Steel". They no longer sell tin valley gaskets & recommend using a thick composite one, so I've ordered that as well. Today Taz & I have been up to Luton in Bedfordshire to drop the Pop propshaft off at "Reco-Prop". I wanted them to weld the UJs on either end of our shortened tubes & balance it, but they've recommended making a new, 3 inch diameter, single piece prop & re-using our UJs on it. Just have to check a one piece tube won't foul the chassis cross members & re-check the overall length before they start on it.
