May 18, 2024, 06:33:44 PM *
Pages: 1 [2] 3 4
Author Topic: wiring  (Read 14312 times)
dobber
« Reply #15 on: December 18, 2011, 08:24:27 PM »
hi tbone,mike.
bike was a m plate, 900. pretty sure it does have the passing light switch on the left hand cluster.
lot easier to start from scratch i guess but that would be too easy. be really grate full if you could point me in right direction t bone.  one bit at a time as someone said in a previous thread.
        can i have it in 20 Min's?
« Reply #16 on: December 18, 2011, 09:06:03 PM »
I`m sure we can figure it out between us  Wink
what fusebox have you got? got a picture?
dobber
« Reply #17 on: December 19, 2011, 10:15:20 AM »
bought a 8 gang simple  fuse box with clip on clear cover on spur of the moment tbone.[ picture up later]
 new place opened in town [wakefield] that specialises in classic car stuff. going back today for some starter motor wire cos the stuff i have in is far too heavy
« Reply #18 on: December 19, 2011, 11:08:00 AM »
8 gang is great   Grin
i`d use 25mm2 cable from the solenoid to the starter  Wink, it`s 10mm OD (as near as dam it) and 170amp rating.
For the alternator, 16mm2 will be fine, it`s 7.5mm OD with a 110amp rating.
You may wanna pick up a standard 30amp 4 pin relay while you`re there, for the starting circuit.
« Last Edit: December 19, 2011, 11:17:00 AM by tbone » Logged
« Reply #19 on: December 19, 2011, 12:16:11 PM »
Perhaps for your amusement Mr.T, and to show how much motorcycle and car 'elektrikery' have advanced, yeah, right!! check out the two wiring diags. attached, both early '50's BSA and Standard, and both from vehicles previously owned by myself in the later '50's, and copied from handbooks I bought at the time of ownership,and which are still on my bookshelf,priced at 6/- and 7/6,respectively!.....hey ho, past times, mutter...mutter.....Nadolig Llawen pawb,  Morrag
« Reply #20 on: December 19, 2011, 08:12:03 PM »
A far simpler time in lot`s of ways Morrag, if not a little before my time.
Information such as that is priceless, i only wish i`d realised that when starting out tinkering with automobiles!
« Reply #21 on: December 19, 2011, 11:27:52 PM »
I remember them black and white tellies,
I've got a colour one now.
http://i391.photobucket.com/albums/oo355/Triumph-Wales/Brit/basicwire01.jpg
I nicked this off another forum,But i don't think they will mind.
   I think it's borgs.
« Last Edit: December 19, 2011, 11:30:20 PM by hunter » Logged
« Reply #22 on: December 19, 2011, 11:34:42 PM »
Starting circuit, that would be yer right leg then................
dobber
« Reply #23 on: December 20, 2011, 05:12:29 PM »
set the fuse box and old solonoid up on a bita timber, got the frame  and engine earthed and to the battery, cable from starter to solonoid, then solonoid to battery.
starting with the kill switch, start button and front brake light.
6 pin connector, brown wire and green/yellow wires are brake light
red/thick white
red/thin white
black
blue/white
 the two red and white have continuity when kill switch on run.
held the start button in and doesnt make any difference to continuity on any wires.
ignition has thick red  and thick blue/brown wire , continuity when ignition on
other wires are in a four block conector
blue/red
blue/white
blue
blue/black
ignition has on  off and park setting.
can start here and try move a bit at a time.
dobber
« Reply #24 on: December 20, 2011, 05:15:24 PM »
got 3 pins on alternator, never kept plug...
« Reply #25 on: December 20, 2011, 05:53:42 PM »
Small spade is the warning light, other 2 are output. The output terminals are connected internally so doesn`t matter which you use.
« Reply #26 on: December 20, 2011, 06:02:47 PM »
red/thick white
red/thin white
black
blue/white
Brake Light Switch:- Brown wire is in, Green/Yellow is out.
Red / thick White  :- Feed to fusebox
Red / thin White    :- Feed to ignition coil
Black                   :- Earth
Blue / White         :-  Feed to starter solenoid
« Reply #27 on: December 20, 2011, 06:19:37 PM »
blue/red
blue/white
blue
blue/black
Thick Red      :- is feed in from the Fusebox   (run a lead from the battery to this fuse)
Blue / Brown  : - feed back to fusebox
Blue / Red     :- feed to rear light and front auxiliary lights
Blue / White   :- POSSIBLY feed to digital clock Huh
Blue              :- feed to headlamp switch and idiot lights
Blue / Black     :-
Not sure on the other 1 mate  Huh
« Last Edit: December 20, 2011, 06:35:07 PM by tbone » Logged
dobber
« Reply #28 on: December 20, 2011, 06:44:33 PM »
off in garage now to make a start.
the one that feeds the coil tbone, will it be strong enough for the reliant coil[ guess a sparks a spark]
and the one you said "feed to fuse box" i just put a wire from battery to fuse box and up to the red and thick white.
how many roughly, of the fuses want to be live from the battery, will link them up now..
really appreciate this.
« Reply #29 on: December 20, 2011, 07:01:24 PM »
At the moment, you only need 1 live fuse, the thick Red one. attach a lead from the battery to one side of the fuse and the Red wire to the other side.
Run the thick Red / White to one side of the second fuse and the thick Blue / Brown wire to the other side of the second fuse.
« Last Edit: December 20, 2011, 07:23:44 PM by tbone » Logged
Pages: 1 [2] 3 4
