May 16, 2024, 08:26:40 PM *
Pages: 1 ... 128 129 [130] 131 132 ... 791
Author Topic: Manky's Pop.  (Read 1564458 times)
« Reply #1935 on: April 03, 2010, 07:23:17 PM »
Box drilled & studs bolted in -& yes, I've drilled an 8mm drainage hole in each corner too.
« Last Edit: April 03, 2010, 07:31:55 PM by Manky Monkey » Logged
« Reply #1936 on: April 03, 2010, 07:29:06 PM »
I'd planned to use wing nuts to hold the strap down, so I wouldn't need a spanner to remove the battery, but there's not enough room for them. As the box won't have a lid on it, Loony suggested making a pair of T handled nuts instead.
Can anyone knock me up a couple of lengths of mild steel threaded tube -say 12mm diameter by 60mm long, drilled & tapped the full length to M8?
« Last Edit: April 03, 2010, 09:47:25 PM by Manky Monkey » Logged
gazzagood
« Reply #1937 on: April 03, 2010, 11:13:00 PM »
i can get ya some connectors from work on Thursday and post um to ya if that's any good to ya  (sir) but they only 50mm long with m8 hole threaded all the way thought about 12mm hexagon  Kiss
gaz
PLEASE
« Reply #1938 on: April 04, 2010, 08:33:34 AM »
Yes please Gazz, that'd probably do the job. They need to be mild steel so I can weld a rod across the top to make a T handle.
Thanks mate. Let me know how much I owe you please.
gazzagood
« Reply #1939 on: April 05, 2010, 03:00:26 PM »
no problem mate ill get um posted to ya thurs/fri may be galv but if you weld it as ya know keep ya nose and mouth shut Grin
gaz
PLEASE
« Reply #1940 on: April 05, 2010, 10:13:51 PM »
Thank you Sir.  Kiss
« Reply #1941 on: April 06, 2010, 07:28:16 PM »
Back at t'workshop, Loony's made a start on the side panels for the pick-up bed. If you haven't been following the plot so far, rather than just making a straight sided square box, we're using VW camper van repair panels to give it a bit more shape. Here you can see Loony's folded up some lengths of flat sheet to form horizontal struts between the frame uprights. These will give him something to tack the panels to if needed.
« Reply #1942 on: April 06, 2010, 07:41:53 PM »
The V Dub panels flare out over the wheel arch then curve under at the bottom. We're using lightweight cycle type mudguards over the tyres, so the arches only have to step over the axle, not cover the wheels. After a bit of trial fitting, we decided the arch opening looked best cut to the same width as the tyres. So we sliced up the repair panels then Mr L cut & shut the arches to suit. Rather than just butt welding the cut edges together, he used a joddler to produce a step in the edge of one panel so that it slips under the other to create a flush joint. The overlapping edge was then drilled & plug welded, being careful to keep the heat to a minimum so as not to distort the thin sheet metal. Eventually the joint will be seam welded & with a light skim of filler, should be invisible.
« Reply #1943 on: April 06, 2010, 07:45:09 PM »
The double curves of the lip of the arch couldn't be "joddled" with Loony's hand held tool, so had to be butt welded, but being shaped, they were much less prone to disortion than the flat areas of the panel.
« Reply #1944 on: April 06, 2010, 07:54:35 PM »
From the side, the arches won't really show, but once you step to one side or the other you can see though them to the shocks & 4 bar suspension linkages underneath. That'll hopefully hint at something a little clever under the 1950s truck body.
« Reply #1945 on: April 06, 2010, 07:59:47 PM »
A rare sunny day today, so time to shove the Pop out of the workshop & have a look at our progress.
The seemingly endless damp weather has added a film of surface rust to even the most recently made parts. Hopefuly it'll just buff off, but does make the truck look a bit scruffy.
« Reply #1946 on: April 06, 2010, 08:03:43 PM »
We're happy with the look of it so far.
NeilG
« Reply #1947 on: April 06, 2010, 08:08:37 PM »
Oooh,looking purty  Grin
« Reply #1948 on: April 06, 2010, 08:13:10 PM »
Only from one side Neil! Walk around the other side & it looks like a film set, mocked up for the camera.
« Reply #1949 on: April 06, 2010, 08:20:20 PM »
You can see how far the side panels will extend below the chassis. That'll hide the fuel tank & battery box as well as the chassis rails. We've talked of extending the fronts down to meet the bottom of the cab. That would also hide the bottom 4 bar rods. On the other hand, keeping the bottom edge higher might balance out the front end panels when they go on. The bonnet sides will follow the sweep of that curve in the door panels. Not sure yet.
« Last Edit: April 06, 2010, 08:26:10 PM by Manky Monkey » Logged
