Technical Section => General Tech => Topic started by: Olds on October 05, 2017, 08:44:27 AM
Title: MX5 emissions
Post by: Olds on October 05, 2017, 08:44:27 AM
D'oh!
The MX5 had it's mot yesterday and failed. :'(
Not on a lot, well actually only one thing. The emissions so I suppose I should be grateful, as on a seventeen year old Mazda, it could have been worse.
Fast idle CO reading was too high (0.59%) but he lambda reading was spot on (1.0) and HC reading good (49 ppm), so it looks like a new catalytic converter is needed. :'(
Title: Re: MX5 emissions
Post by: Manky Monkey on October 05, 2017, 09:19:23 AM
I wouldn't have a clue how to remedy emmisions. Fortunately my Pop was tested on the age of the engine, so just the very basic emmision requirement.
Post by: Archie on October 05, 2017, 04:13:14 PM
try an Italian tune up first - 9 times out of 10 when we had cars fail a tin of engine gunk rubbish and getting the car nice and hot was enough to get it through. Especially if you're that close to passing
Post by: Olds on October 05, 2017, 04:25:27 PM
Did that. Didn't realise it would do 55 in second. Went back and slightly better but not enough. Think the cat has a slight rattle so is possibly starting to break up. The whole exhaust system while not leaking is not in the best of condition and wont come apart without help from Mr Grinder, so I will replace the lot.
Post by: Olds on October 11, 2017, 10:36:58 AM
Got the old exhaust off and I'm astounded that the emissions, while not being good enough, were as good as they were.
There is no catalytic converter ! Well there is and there isn't. The casing is there, but the honeycomb  inside, isn't ! :o
Just waiting for the rain to stop so I can fit the new exhaust system without getting wet again.
Post by: Manky Monkey on October 11, 2017, 10:58:16 AM
Deliberately removed Dave, or just burnt away?
I really don't know anything about "cats". How exactly do they work? Do they just absorb particulates, like a filter?
Post by: morrag on October 11, 2017, 12:56:09 PM
From my schoolboy chemistry, back when Chemists were still called Apothecaries! ;D a catalyst is an element or compound which, during a chemical reaction, increases the rate of change of that reaction without itself permanently altering. In the case of the internal combustion engine, removes some of the "nasties", such as Carbon Monoxide etc, from its exhaust gases....Morrag
Post by: Manky Monkey on October 11, 2017, 01:10:47 PM
So a chemical, rather than physical filter then? How does that work in practice? A perforated tube baffle that the particles pass through, breaking them down to an acceptable level before they leave the exhaust?
Just curious cos I've never worked on one.
So why do the boy racers remove them? Just to make the exhaust more free flowing & release many hundreds of extra horses in their 1 litre Corsas?
Post by: Stix on October 11, 2017, 01:47:24 PM
https://www.youtube.com/watch?v=nM9mdY10ZTU  lets you know how they work with a video
Post by: morrag on October 11, 2017, 02:27:07 PM
Nope, it's not filtration, it's the ability of a catalyst, in the case of combustion emissions a compound/alloy of platinum, to chemically modify a dangerous gas, CO, and change it to a non dangerous state, whilst the catalyst remains in its original state. A purely chemical reaction, called  redox......more or less ??? ??? ??? ???
Post by: Olds on October 11, 2017, 02:29:42 PM
 ;D
Think mine had just disintegrated. It was a genuine Mazda unit, so was probably the original. Close on 100,000 miles isn't to bad for one of these.
 Boy racers remove them as it's a lot cheaper than buying a free flowing sports cat and makes the exhaust slightly noisier. Probably very little  performance gained by removing it. A bit like using a dustbin as a silencer, it's wot we duz init.  ;D
Post by: the coppersmith on October 11, 2017, 02:41:45 PM
If you remove the cat you will fail emissions at MOT time, many of the "younger" element near me, replace the cat at MOT time, and then remove for 12 months. Those cats are worth a lot at scrap time and local villains are knwn to take certain large cars and pinch the cat only, then abandon the car. Big Merc's by all account have huge cats, according to the grapevine  ;)
Post by: Olds on October 11, 2017, 03:04:33 PM
A few years back local ambulances that were not on duty (service, cleaning,restocking etc.) had their cats cut out over night. Caused a LOT of problems and put lives at risk. The amount of platinum, palladium and rhodium used now is not as much as it used to be, but they are still a target.
Anyone nicking the cat from my MX5 would have been very disappointed.
Post by: Manky Monkey on October 11, 2017, 03:22:56 PM
Same thing happened to the Post Office Van fleet Dave. Probably the same low life's as our yard's just up the road from the ambulance station. Also had the diesel storage tank drained twice.
Post by: Olds on October 11, 2017, 05:23:05 PM
What you should and what you should not see looking into a cat.
Post by: Manky Monkey on October 11, 2017, 08:55:15 PM
 ;D
Post by: minimutly on October 12, 2017, 07:15:50 AM
I think you, or possibly the revious owner? Were lucky the bits went out the back, i clouted one of mine years ago, within two days the car wouldn't run past 3000 rpm on full load (or any load), it just whistled and died. The cat was in bits inside, and toally blocked..
Post by: Olds on October 12, 2017, 11:49:37 AM
Yep, heard of that happening. Usually after hitting one of those 'raised cushion traffic calming measures'. >:(
Well with new system in place it passed with a CO reading of 0.04 %  :)
Think it would have to be electric to get much better than that.  ;D
Post by: morrag on October 12, 2017, 12:50:57 PM
So, the calming measures work then................. :D
Post by: Archie on October 12, 2017, 01:02:46 PM
But is it slower now?
Post by: Olds on October 12, 2017, 01:24:11 PM
Don't think so but it is a bit quieter.
They work fine, if your business is replacing exhausts and suspension components.
We have a short stretch of road here that has 15 humps a two raised junctions. A lot of folk can't or won't drive down it due to the damage or pain it has caused.
Post by: minimutly on October 12, 2017, 06:31:32 PM
The problem with them is they go too far - ensuring people keep to 20 or 30 is one thing, but you have to drop to 10mph or so to avoid having issues, then speed up again.
Finally people have caught on, and in the interests of emissions and the environment they're talking of removing the things.
Post by: Manky Monkey on October 12, 2017, 08:34:08 PM
The ones Dave mentioned were removed -then put back again!
Post by: Baychimp on October 12, 2017, 09:24:30 PM
I always found on that stretch of road you could go as fast as you liked, if you were in a post office Transit, as the wheels fitted either side of the hump. Get upgrade to a bigger van Andy. ;D ;D
Post by: Manky Monkey on October 12, 2017, 09:46:44 PM
Or a bicycle.
Post by: the coppersmith on October 17, 2017, 12:18:26 PM
Just been to the scrappie, sorry should say vehicle dismantler/recycler  :D looking for some exhaust pipe for the project. Took me around the yard and I noticed two piles of silencers. "Why 2" I ask? I now have a science lesson on Catalytic converters. It seems petrol and diesel are different valuable metals ! Diesel is Platinum and not worth as much as petrol which are Palladium. Since the diesel emission scandal scrap prices have fallen for Platinum. There you go, an average scrap man with knowledge of physics and chemistry  ;)
Post by: Manky Monkey on October 17, 2017, 08:27:32 PM
I used to love Sunday night at the Palladium.
Post by: Baychimp on October 17, 2017, 11:17:14 PM
Showing your age now. :D :D
