May 08, 2024, 05:09:01 PM
For Sale
trailer for sale
Topic: trailer for sale (Read 1607 times)
dobber
trailer for sale
March 26, 2011, 02:57:15 PM »
gonna be moving on this trailer shortly, hopefully for 200 quid as the trike can be moved on its own. it makes a good work bench for setting up a trike or whatever and then you can move it if in the way with out having to reset everything up plus its a lot better work height and your not on your knees all the time.
ideal for moving projects for tests, shows or taking for work doing
10 ft x 7ft bed plus towbar
all steel chassis with a 1 1/2 inch box section sub frame with cross pieces every 2 ft welded on, 13 inch wheels with good tyres in center.
can cover it with shults to pretty it up when checked over if needed
corner jacks which will lift it off the ground if needed and you can put the spirit level on for a perfectly flat work base
covered in18mm marine ply riveted down
got a pair of plastic arches for it ,removable so not in the way
all the brakes and leg jacks working fine
will need a 5ft minimum lighting board to tow it away.
can i have it in 20 Min's?
Re: trailer for sale
March 26, 2011, 04:59:11 PM »
old caravans never die...........................enterprising people make them into very handy trailers
dobber
March 26, 2011, 06:00:44 PM »
towing end
