ha ha ha.
well got round to do the welding for the seat.
took abit of fiddling around and trials with blocks of wood and shock positions but got there in the end.
cut and ground out the previous work. i had cut and drill all the bits up before going there. welded the tabs to the new seat back. i drilled holes above and below the mounting holes i had planned to use just incase i wanted to move it up or down in the future.
my new trike project
then welded tabs to base plate and fixed that in position
mounted the shocks and rode home. next gave it a lick of paint where i could and now looks like this.
i am a happy bunny.
the seat is now a lot lower and closer to where it was originally. with the two shocks on it doesnt wobble side to side and i feel safe going round corners. haven't been able to go to far yet,been busy at work, but plan a ride out on my lunch today. but i can already tell the difference on the short run to work. three bumps that used to rattle my spine are now just lumps in the road
when i do hit bigger bumps the seat stays under my bum rather than me flying in to the air and coming back down on to it.
