« Reply #180 on: June 21, 2015, 07:54:23 AM » |
Think you are doing great Morrag Must admit that most small dings I'm not to worried about on mine and though it's going to be painted, I wont use filler on ally panels. I figure it's going to end up with loads more dings in use. Once the panels have been riveted on getting dents out will be much harder. Small dings I try to gently hammer out. If the material has stretched I go for the heat it up locally and push it into shape approach while hot and rarely use a steel hammer direct onto the aluminium. This is my favourite shaping tool. A bit of mahogany chair leg. The ends are now scorched and it's getting bruised (a bit like me ).
« Last Edit: June 21, 2015, 08:04:48 AM by Olds »
« Reply #181 on: June 21, 2015, 09:43:50 PM » |
Cheers for that info. Dave, and I now have my own, personal, table leg tool! although the wife's still giving me earache about the dinner slipping off the table now ...oops, just realised you said chair leg, ho hum, well too late now, and anyway, I blamed you..... ..Morrag
« Reply #182 on: June 21, 2015, 10:54:28 PM » |
« Reply #183 on: June 22, 2015, 08:07:10 PM » |
So, from what you imply Dave, that is unlikely to be Ikea, or MFi then, so that,s me buggered.........................
« Reply #184 on: August 30, 2015, 07:17:57 PM » |
Well, after three years and a bit, close-ish to the finish line. I shall have to post the pics one at a time as even severely reduced in size, its a problem to do otherwise!! Morrag
« Reply #185 on: August 30, 2015, 07:25:20 PM » |
The front mudguards, rad. trim and boot are all steel, hence the need for paint! Morrag
« Reply #186 on: August 30, 2015, 07:28:40 PM » |
« Reply #187 on: August 30, 2015, 07:29:19 PM » |
Looking very nice Sir. Don't remember the green paint when I saw it in the flesh.
« Reply #188 on: August 30, 2015, 07:33:48 PM » |
The paint is Arc-Rite Machinery & Tractor enamel, and it appears you can brush paint it with good results, so I understand, however I sprayed this on, nearest they had to BRG, although I think it's probably a John Deere colour!! ..Morrag
« Reply #189 on: August 30, 2015, 07:37:41 PM » |
I like it lots, but then half my projects have ended up green.
« Reply #190 on: August 30, 2015, 07:39:20 PM » |
That went on in the lowering gloom of the end of the day last Thursday! Mr. M. in the poor light of my inner workshop, but having been waylaid hanging an outside door for my younger son for most of the day, that was the only time to fit it in! still its ok, just !:D.. but I would use the paint again as the shine is excellent, and it should be hard wearing from what it is more commonly used for, don't you think? Morrag
« Reply #191 on: August 30, 2015, 07:42:54 PM » |
Near side of the GL motor, complete with household plumbing!!!.....
« Reply #192 on: August 30, 2015, 09:04:30 PM » |
your trike looks really tidy ,good job
« Reply #193 on: August 30, 2015, 09:06:41 PM » |
Coming on very nicely. Liking the colour. Lighter than the more common BRG and should fit right in at agricultural shows.
« Reply #194 on: August 30, 2015, 10:12:46 PM » |
Last one for now....
