« on: January 11, 2014, 05:14:16 PM » |
Yeah, I know, it's my own fault. Having almost single handedly wiped out the supply of cheap Reliant donors, I'm now looking for a Regal axle for a T bucket project. Anyone?
« Reply #1 on: January 11, 2014, 05:58:15 PM » |
I assume it has to be a Regal one, to allow for larger diameter rims.
haggis
« Reply #2 on: January 12, 2014, 03:43:11 AM » |
I would't blame yourself for almost wiping out the reliant axle population mate. I have the guts of 12 sat in my workshop. But non are Regal unfortunately.
« Reply #3 on: January 12, 2014, 11:45:04 AM » |
Never had a Regal one before, but certainly killed a few Robins & Rialtos over the years & encouraged the rest of the World to do the same. Yup, the gearing would better suit the 28" ish diameter wheel/tyre combo. The Regal axle casing also happens to look more like a vintage one. The other option for the back of the T bucket is a Triumph Spitfire IRS. Much easier to set up & better gearing, but not really the ol' school look we're going for.
« Reply #4 on: January 12, 2014, 11:52:56 AM » |
What sort of width is the Regal ,or any Reliant axle outer face to face ? You may find it looks too narrow ?
« Reply #5 on: January 12, 2014, 12:07:59 PM » |
I seem to remember my last trike being about 48" overall width, (wheels on axle).
« Reply #6 on: January 12, 2014, 12:47:33 PM » |
Might be easier to find a pop axle or similar these days.
« Reply #7 on: January 12, 2014, 01:07:01 PM » |
About the same as an Anglia then,and that tends to look narrow against a T body. I'll try to send you a photo of my 23 with a 52" wide axle and that still looks too narrow to me ,even with wide rims.
« Reply #8 on: January 12, 2014, 01:14:45 PM » |
how about an escort axle then youlle have a good choice of ratio,s
thebigdogsix
« Reply #9 on: January 12, 2014, 02:08:46 PM » |
How do you tell if its a regal axle
« Reply #10 on: January 12, 2014, 02:59:11 PM » |
Why not use a Morris thou axle,They come in a lot of different ratio's. Regal rear axle.
« Last Edit: January 12, 2014, 03:01:40 PM by hunter »
« Reply #11 on: January 12, 2014, 06:40:11 PM » |
How do you tell if its a regal axle well you know a robin /rialto one has a ring of studs n, nuts on one side of the diff casing ,,, the old regal ones have a ring of studs n, nuts on both sides and i,v even come across them with long nuts n, bolts (approx 4 inchs long ) that go straight through also a dead give away on early ones is the rod brake linkage.
zakboy
« Reply #12 on: January 18, 2014, 08:52:39 AM » |
regal diff housing.........but would not have the section cut out like this one
« Last Edit: January 18, 2014, 08:58:21 AM by zakboy »
« Reply #13 on: January 18, 2014, 09:55:45 AM » |
Cut out section's for chain drive for a trike. Moggy Minor axles used to be popular for the same treatment. Mr Loon's actually got a Moggy axle. Anyone know how to tell what ratio it's got & whether it'd be any better than the standard Rialto one?
« Reply #14 on: January 18, 2014, 10:36:38 AM » |
Unless you know the age of the axle, it's going to be either roll it and count the turns or strip and count the teeth. I think these are the ratios. All would allow taller wheel/tyres. 1952-56 = 5.286:1? 1956-62 = 4.55:1 1962 on = 4.22:1 (1098cc) 1962 on = 4.55:1 (1098cc van and pickup) GPO Vans = 5.375:1
« Last Edit: January 18, 2014, 10:48:51 AM by Old Newbie »
