May 09, 2024, 11:44:18 AM *
Pages: [1] 2 3 4
Author Topic: Bleeding Brakes!!  (Read 13459 times)
« on: December 03, 2008, 12:13:12 AM »
To bleed your Brakes you will need:
•   A new bottle of the recommended Brake Fluid  ( dot 4 will suit most )
•   A length of rubber hose - that fits tightly over the Brake Bleed Nipple and will reach the floor.
•   A spanner to undo the Brake Bleed Nipples.
•   And a clean jar or plastic bottle to collect the old Brake Fluid into.
« Last Edit: December 06, 2008, 08:05:39 AM by tbone » Logged
« Reply #1 on: December 03, 2008, 12:14:38 AM »
Yes boss, pics to follow... will do them for the weekend.  Wink
« Reply #2 on: December 03, 2008, 12:22:39 AM »
Thanks Workshop Monkey  Grin
We'll have your caliper plate essay online by the weekend too -promise.  Wink
« Reply #3 on: December 06, 2008, 08:08:29 AM »
Bleeding the brakes:
Remove the reservoir cap and take out the rubber diaphragm that is normally fitted inside, top up the reservoir to the maximium Level and refit the diaphragm and the cap.
« Reply #4 on: December 06, 2008, 08:10:20 AM »
Remove the rubber grommet from the Bleed Nipple on the brake caliper or wheel cylinder and squeeze the hose onto the Nipple.
Pour between one and two inches of Brake Fluid into your jar and drop the end of the hose into it, this will prevent any air being sucked up into the brake system when the bleed nipple is opened.
« Reply #5 on: December 06, 2008, 08:12:20 AM »
If its the rear brakes that you are doing, release the handbrake lever, assuming you use it!
You will then need to either squeeze the brake lever or depress the brake pedal (depending on whether you are doing the front or the back) hard and whilst maintaining the pressure, open the bleed nipple half a turn.
As the Lever or Pedal completes its travel a small amount of fluid will be released into the jar and you should see air bubbles escaping from the bottom of the hose.
The Bleed Nipple must then be tightened just as the lever or pedal reaches its stop.
When the Bleed Nipple is tight the lever or pedal can be released again back to its normal position
Repeat this process-applying pressure, opening bleed nipple, let lever/pedal complete its travel, tighten bleed nipple, and release lever/pedal.
This will be repeated about four or five times before you will have to remove the reservoir cap & diaphragm and refill the reservoir with the new Brake Fluid,  DO NOT LET THE RESERVOIR RUN DRY OF BRAKE FLUID.
This process must be repeated until brake fluid being spent into the jar is free of any air bubbles, you should notice a firmer feel to the lever/pedal when the bleed nipple is tightened.
When this has been achieved the bleed nipple must be tightened down properly.
Remove the hose from the bleed nipple and replace the rubber grommet.
You have to repeat this procedure for each caliper or wheel cylinder so if you are doing the front you will have to bleed the calipers on either side of the forks and obviously each wheel cylinder per axle side.
Re-check the brake reservoir and top up if necessary-making sure not to overfill as when you come to replace the diaphragm and cap it might overflow- and Brake Fluid will eat its way through your paintwork very very quickly.
You have now completed the task of bleeding your brakes.
« Last Edit: December 06, 2008, 07:43:31 PM by tbone » Logged
« Reply #6 on: December 06, 2008, 08:15:39 AM »
Changing The Brake Fluid:
Brake Fluid is Hygroscopic - absorbs moisture - this moisture can permeate through the brake hoses and contaminate the brake fluid.
The water in the system will then heat up under braking and can form vapor locks which in turn will destroy the effectiveness of the brakes.
So changing the brake fluid at regular intervals will prevent this happening, and this is also easy to do
It is the same process as bleeding the brakes, except that you open the bleed nipple and operate the brake lever/pedal to pump out the existing old brake fluid.
A small amount will be left inside but not enough to make a difference.
Top up the Reservoir with new clean brake fluid as continue to operate the brake lever/pedal until you see the new clean brake fluid coming out of the hose.
This should have flushed out the last bit of old brake fluid.
Close the bleed nipple and then bleed the system as described above.
« Reply #7 on: December 06, 2008, 10:42:06 PM »
Thanks TB, we'll transfer that to the tech sections of the Motors bit of the main site as soon as we can.
« Reply #8 on: December 15, 2008, 12:20:43 AM »
Added to the Motors sections of the main site. Thanks TB.  Wink
« Reply #9 on: December 15, 2008, 09:21:59 PM »
A pleasure as always Wink
« Reply #10 on: December 16, 2008, 07:51:59 PM »
Next!
« Reply #11 on: December 16, 2008, 10:14:36 PM »
Next? hmm what to do next? ah, thats it, i know. will post it shortly for you!  Wink
« Reply #12 on: December 16, 2008, 10:19:37 PM »
I await your next essay with baited traps breath.
« Reply #13 on: December 16, 2008, 11:07:54 PM »
Ok its posted complete with pics, i`ll enjoy the fruits of my labour before i do the next article Grin
« Reply #14 on: December 16, 2008, 11:47:56 PM »
 Grin Thanks TB!
Pages: [1] 2 3 4
