May 16, 2024, 08:38:56 PM *
Pages: 1 ... 8 9 [10]
Author Topic: exhausting work  (Read 24965 times)
tony b
« Reply #135 on: August 18, 2009, 05:18:36 PM »
exelent progress mate but i have to ask,have you turned the gas on ,on yer welder as some of the joints look dry.
« Reply #136 on: August 18, 2009, 05:20:42 PM »
When it was finally taking shape, i could see where i needed to cut to get the front and rear halfs the same length.
« Reply #137 on: August 18, 2009, 05:26:55 PM »
Yep gas is on, because i`m only tacking, i`m working with one of those disposable cylinders and as we all know, they are barely up to the job, and not helped by the fact i have the door open, but all the final welds will be done once i connect the large cylinder.
« Reply #138 on: August 18, 2009, 05:32:06 PM »
Much bending trimming and tacking ensued
« Reply #139 on: August 18, 2009, 05:34:47 PM »
but eventually it all came together and the back is now tacked in too. And thats that, as mentioned above, i need to fully weld it then clean it up a touch.......
« Last Edit: August 18, 2009, 05:37:07 PM by tbone » Logged
« Reply #140 on: August 18, 2009, 05:38:33 PM »
And when thats done i can fit it and the pipe thats gonna attach to it  Wink
« Reply #141 on: August 18, 2009, 10:18:42 PM »
That's very tidy TB. What's the new pipe from? Is that a pre-formed 90 degree bend?
Just shows what can be done with simple hand tools eh.
« Reply #142 on: August 19, 2009, 06:50:45 AM »
Its not the tools that are simple, just the guy using them  Grin.
I`m not sure what the pipe`s exact original use was, i got it from a guy that was fitting out a shop, it`s got a black coating of something over it that is hiding stainless steel.
Yep the bend was pre formed, its half a mill smaller ID than the standard reliant pipe, so should do me nicely.
voodoo
« Reply #143 on: August 19, 2009, 08:57:55 AM »
Very nice mate.....now you have done all the hard work I will follow your lead and make up my Reliant exhaust soon  Grin.......Voodoo....
Custom Paint Spraying...
« Reply #144 on: August 19, 2009, 10:38:06 AM »
Thats what its all about, If you cant buy it, you gotta make it  Grin.
Just one last point to add, and that is....watch your ground clearance, If i was to do another one, i`d raise the collector box by an inch & half or so.  Wink
