Simple Simon
Champion Air Rider
« Reply #135 on: April 27, 2009, 06:41:01 PM » |
With your usual flare and precision I hope Mr T'
I will do it! I will do it! I will do it! I will do it! ........ well in a minute.. or... tomorrow..... OK maybe next week!
« Reply #136 on: April 28, 2009, 06:10:52 PM » |
only time will tell , but first its time to mount the coil. And i`m gonna put here....
« Last Edit: April 29, 2009, 06:18:58 PM by tbone »
« Reply #137 on: April 29, 2009, 06:26:11 PM » |
and this is how i`m doing it. First thing i need is a couple of angled brackets, i`ve got a fair bit of 3mm angle iron so cut mine from this, you can of course use some strap and just bend it.
« Last Edit: April 29, 2009, 06:38:23 PM by tbone »
« Reply #138 on: April 29, 2009, 06:28:39 PM » |
So now i have to line it up with the stud at the top and mark it to drill an 8mm hole.
« Reply #139 on: April 29, 2009, 06:30:14 PM » |
With the hole drilled, i can weld it to the original coil clamp.
« Reply #140 on: April 29, 2009, 06:32:57 PM » |
the bottom end is done in the same way, only the bracket is horizontal instead of vertical, here i used the top mounting bolt for the starter motor and drilled my bracket to 10mm to suit.
« Last Edit: April 29, 2009, 06:37:25 PM by tbone »
« Reply #141 on: April 29, 2009, 06:35:51 PM » |
time ran away with me so i`ve not finished it yet, but you get the general idea
« Reply #142 on: April 29, 2009, 07:30:22 PM » |
Nice & tidy TB.
« Reply #143 on: April 29, 2009, 09:06:22 PM » |
Not quite the engineering in mine as in yours, but like me, its simple and does the job
« Reply #144 on: April 29, 2009, 10:42:32 PM » |
Simple usually turns out to be best.
« Reply #145 on: May 12, 2009, 05:20:17 PM » |
This is something i nearly forgot, its a hole, well a threaded hole to be precise, and its in the top of the head at the back. At some point it would have had an adapter screwed in to take a water pipe, i dont need this so need to blank it. A 5/8" unf bolt will do the job nicely. I`ll cut it down, wrap the threads with PTFE tape, the stuff plumbers use, and screw it in tight, sealed, job done!.
« Reply #146 on: May 12, 2009, 06:10:07 PM » |
The original fitting has a tapered thread, so seals itself as it tightens down, but a turn or two of PTFE plumber's tape helps. I just cut the top off the fitting & welded it over.
« Reply #147 on: May 12, 2009, 07:07:36 PM » |
i didnt have the original
« Reply #148 on: May 21, 2009, 04:03:59 PM » |
A small step today, but its step closer . I cut down the bolt (shown above) then cut a slot across the top, wrapped the bottom half in ptfe tape then screwed it in. And that i think is the head finished!
yanto
« Reply #149 on: May 22, 2009, 07:35:20 PM » |
nice and neat that seeing all these pics brings back memores
