« Reply #15 on: November 21, 2011, 06:25:19 PM » |
Hi Steve ratio's do my head in to be honest i did a lot of research on the net and found that a 3.91 ratio sierra was as close as for the 1200 wing i may have to play around with tyre size but I'm hoping i wont i have 15 inch 195 tyres on there now . The sierra /Granada /cosworth diffs have a vast array of ratio's they also come in 7 inch and a 71/2 inch the 7 inch diff is a much smaller diff and no not by just 1/2 a inch its quite a lot smaller lol They also come in slide in half shafts or bolt on (lobro) mine is a lobro if the ID plate isn't on the diff telling you the Ratio your gonna have to take the rear diff plate off and the ratio is written on the crown wheel. The rear diff plate can be a right pain to get off ford used star bolts that wont undo the only way to get them undone is to cut the head of the bolt off with a 1mm cutting disk then get the mole grips on whats left i hope this helps and i havent gone on too much lol
Mousy Boy :-) AKA Mick
steve brock
« Reply #16 on: November 21, 2011, 06:26:33 PM » |
Isn't the drive shaft to the left how'd ya get it to the middle?
« Reply #17 on: November 21, 2011, 06:28:12 PM » |
Hi Mouse Was it you who bought a trike that needed msva registering and had a thread about it on this site, if it was you could you lead me to it please. If not sorry for pestering you
your not pestering me Merv unfortunately it wasn't me i have built 5 trikes but not had to MSVA any of them due to "Bolt on option " if theres any help you need and i have the answers please feel free to ask like i said your not pestering
« Reply #18 on: November 21, 2011, 06:31:36 PM » |
Isn't the drive shaft to the left he'd ya get it to the middle?
the drive shaft on the wing is to the right as you sit on the bike the shaft will be very short and have a slight but nothing to worry about angle i know its good practice to get the shaft as straight as poss I've built all mine with a slight angle and have never had any problems
« Reply #19 on: November 21, 2011, 06:47:07 PM » |
thanks ..if only i could get tha file for it id get them cut myself ..ummmm
I can let you have some PDF`s, but you`d need to re draw in autocad, cos i cant be bothered.
« Last Edit: November 21, 2011, 06:53:37 PM by tbone »
steve brock
« Reply #20 on: November 21, 2011, 06:56:17 PM » |
No prob I can draw them up in 5 minutes! Do you make them t bone?
« Reply #21 on: November 21, 2011, 07:43:59 PM » |
Steve, PM sent.
I looked into IRS 4 or so years ago as my next project, ended up going with the reliant instead.
RODeo
« Reply #23 on: November 25, 2011, 09:24:34 AM » |
Mouse,this is a good project! Looking at the first pics on this thread it looks so simple a design ,but I bet it was a biatch to set it all up square!
« Reply #24 on: November 25, 2011, 09:31:36 AM » |
Mouse,this is a good project! Looking at the first pics on this thread it looks so simple a design ,but I bet it was a biatch to set it all up square! it done me pigging head in mate the problem was i had nothing to work too nothing to compare it too i must have had two weeks sleepless nights thinking about it I'm on a real tight budget too so i couldn't afford to mess up or i would have had to buy another length of 20mm steam pipe @ £36.14
RODeo
« Reply #25 on: November 25, 2011, 05:42:58 PM » |
Ive built ladder type chassis for cars etc over the years,but I found that building my trike frame was difficult as I was having to get all angles symmetrical etc. I described it not as working in 3D,but working in 4D !
« Reply #26 on: November 25, 2011, 05:56:42 PM » |
ive done the same mate built a few hot rods in my time but this took it all out of me i just hope ive got it right
« Reply #27 on: November 25, 2011, 08:11:40 PM » |
steve brock
« Reply #28 on: November 25, 2011, 08:50:07 PM » |
Wot lathe ya got fella?
