May 16, 2024, 03:11:25 AM
General Tech
anybody used one of these Zodiac brian box
Topic: anybody used one of these Zodiac brian box (Read 2147 times)
November 16, 2015, 01:37:06 PM »
http://catalog.zodiac.nl/en/Catalog/04+Lighting,+Indicators+%C3%BE+License+Mount/Lighting,+Indicators+%C3%BE+License+Mount/Wiring+Harnesses+%C3%BE+Modules/THE+ZODIAC+BRAIN+BOX+%C2%A8LITE%C2%A8/Product.aspx
The ultimate solution for "Burned-Out" mini switches. More and more Custom builders are using the "Petit" or "Mini" handlebar switches to operate lights etc. These mini switches can't handle the current flow if used in the same way as the stock switches. The contact area of the mini switches is simply too small and they will burnout. This electronic box will eliminate all problems related to too many Amps flowing through too little switches. It has 4 electronic relays build in that can be activated with a minimum of current flow. This will eliminate all problems related with burning handlebar switches. The thin electric wires needed to connect this relay unit to the handlebar controls can easily be routed inside the handlebar. The Mini-Relays box now has a build-in self-canceling turn signal relay and measures only 3" long, 2" wide and 1" high, so can be fitted easily under a tank or side cover. Comprehensive instructions for ease of installation are included.
Last Edit: November 16, 2015, 01:44:05 PM by mouse
Mousy Boy :-) AKA Mick
Re: anybody used one of these Zodiac brian box
November 16, 2015, 04:54:26 PM »
At 132 Euros, don't think I shall be investing any time soon
mini-relays for heavier loads will do fine for me! Morrag
November 16, 2015, 05:52:13 PM »
Iv used one ,and my mate uses them on and off ? You can get similar things cheaper..zodiac parts are rather expencive
November 17, 2015, 08:43:29 AM »
cheers guys
Stinkey do you what the other makes are ?
November 17, 2015, 09:44:19 AM »
Personaly I would always make my own. Individual relays cost from £4 to about £24 for a latching relay. Vehicle Wiring Products do a variety of relay and fuse boxes, as do CBS.
Last Edit: November 17, 2015, 10:03:40 AM by Olds
November 17, 2015, 10:09:18 AM »
Can't remember off hand ? Try looking on ebay motors (USA ) or contact Simon at Attitude Customs in Southampton ?
