May 01, 2024, 11:37:27 PM *
Author Topic: s u carb  (Read 4271 times)
Firery Fred
« on: January 09, 2014, 09:24:21 AM »
Fancied trying an su carb on my xs, someone piped up that they were available, albeit years ago, for bikes , ie smaller. Anyone any ideas ?
« Reply #1 on: January 09, 2014, 09:53:33 AM »
Smallest SU that I know of is the 1 1/8" used on very early Sprite. Should imagine they would be hard to get in good condition.
Would have thought that 1 1/4" (32mm) as used on Reliant 850 and a lot of other small cars could be used and easier to come by.
Dslam
« Reply #2 on: January 09, 2014, 10:52:09 AM »
Have a look at this link from Burlen fuel systems who reproduce new SU carbs.
Triumph 6T Thunderbird from 1951-56 used an SU (MC2 type)
http://sucarb.co.uk/carbspec/carburettor/spares/id/2504/
If the linky not working just copy and paste.
Hope that helps.
« Reply #3 on: January 09, 2014, 11:12:34 AM »
That's interesting. It's an 1 1/4" SU for motorcycles, with lever choke.
« Reply #4 on: January 09, 2014, 01:03:35 PM »
Get your self an as fitted to 'Mini', or similar 11/4" SU, make up an adaptor flange, and bingo! I have done it several times before,over the years, after all, a carb. is a carb. is a.........if you get my drft!The mid 50's did see Triumph use a purpose built SU on their Thunderbird's, but not for too long.I'm using a larger, probably too large! SU on the 500cc Honda GL motor for my 3 Wheeler, but we shall see how it performs,  Grin Grin Grin Grin...Morrag
« Reply #5 on: January 09, 2014, 01:11:00 PM »
I have attached a pic to illustrate! Huh Huh Huh...Morrag
« Reply #6 on: January 09, 2014, 07:34:35 PM »
There's a guy on Ebay who makes cast aluminium casings & manifolds for XSs.
I bought a pair of inlet manifolds from him to fit Amal carbs to mine, (2nd one down on the left).
He makes them to fit an SU to an XS, (3rd & 4th down on the left).
Cast stuff
« Last Edit: January 09, 2014, 07:36:46 PM by Manky Monkey » Logged
Firery Fred
« Reply #7 on: February 02, 2014, 07:08:36 PM »
Thanks everyone ,my mate has one that might be coming my way,when we can agree a price that I can afford. It's the smallest I've seen but of unknown origin , so we'll see
« Reply #8 on: February 02, 2014, 09:05:30 PM »
On a normal carb venturi affects air velocity = fuelling and pick up . SU is variable venturi so will only rise as far as air requirements though too large a starting point will affect low end torque . Using an SU on a 500c revving to 10,000 then best size woudl be something used on a 1000cc car engine as same CFM requirements to be met at 5000 rpm.
Firery Fred
« Reply #9 on: February 06, 2014, 10:56:23 AM »
He's had this carb on an XS and it ran great once set up correctly
