May 12, 2024, 10:47:21 PM
Trike Tech
LSD or no LSD
Topic: LSD or no LSD (Read 1811 times)
Donut
LSD or no LSD
February 24, 2020, 09:04:05 AM »
Hi folks?
What's you opinion on using a lsd on a trike? and I mean the axle type lsd not the other one!!
I was always under the impression that there is not enough weight for it to operate properly, is that correct or twaddle?
cheers
Re: LSD or no LSD
February 24, 2020, 05:28:05 PM »
Lsd -Limited Slip Diff
Yeah, I had to Google it
Re: LSD or no LSD
February 26, 2020, 09:02:01 PM »
Ask yourself why it might need one? An lsd is to ensure drive to both wheels, maybe when moving off, or going round uphill hairpins.
If your trike has massive power and is likely to wheelspin all the time maybe yes. But you need to know what the downfalls are - if it's anything other than a Torsen type it will likely cause understeer, ie driving straight on through the scenery - is this worth risking?
My feeling is no.
Donut
Re: LSD or no LSD
February 27, 2020, 03:29:33 PM »
Cheers for the reply.
The reason I am asking is that it seem's easier for me to get an limited slip diff opposed to standard, although it is the standard I want as was worried about some of the things you have mentioned and never thought about the others!
Am not in rush so will just wait until I get what I want
Gary
Re: LSD or no LSD
February 27, 2020, 05:28:08 PM »
I would have thought lsd would be ok. A power lock diff would give handling problems on corners and roundabouts.
