May 09, 2024, 06:48:37 PM
Trike Tech
Selecting reverse......
Topic: Selecting reverse...... (Read 1448 times)
May 31, 2009, 06:17:13 PM »
Probably been asked several times before ,and I know Ive read about it on here ,but cant find it!.......
If the bulge is on the l/h side of the box(looking from behind toward the front) where is reverse? Also..is it push lever down ,or pull up? Confused!
Thanx Rod
Re: Selecting reverse......
May 31, 2009, 07:21:35 PM »
The bulge in the gearbox casing, (right at the back, down low near the output flange), is the opposite side to the gearstick movement -imagine the stick passing down through the top of the box & into the bottom of the gearbox. If you push the stick to the left, you'd need a bulge on the right to clear the bottom of the stick. So, if your box has a bulge on the left, your reverse position will be to the right & vice versa.
The stick lifts, acting against a spring under the dome on the top of the box, & goes across, (whichever way your box goes), & back to select reverse.
